using a head from an engine that spun a bearing
Old Oct 27, 2005 | 09:41 PM
zman's Avatar
Default using a head from an engine that spun a bearing
Is it ok to use a head from an engine that spun a bearing? Or should i disassemble hot tank and assemble before using it?
Old Oct 27, 2005 | 10:32 PM
super_nguyen's Avatar
Default Re: using a head from an engine that spun a bearing (zman)
well if your not sure that the head was damaged, don't take the chance, take it apart and inspect it, you don't want to slap it on and find out that somethings bent or damaged. you might not need to hot tank it if its good.
Old Oct 27, 2005 | 11:21 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: using a head from an engine that spun a bearing (super_nguyen)
In theory, the head should be fine. I spun a bearing on my B16 and used the head on my ITR block until i got an ITR head. No problems.
Old Oct 28, 2005 | 04:40 AM
TurboCoop's Avatar
Default Re: using a head from an engine that spun a bearing (JDM_Ej)
yup, I used a GSR head from a motor that spun a bearing on my LS/Vtec and it worked fine. I took it apart and inspected it and everything of course, it looked fine, and it works fine too Sometimes if its bad enough and the motor was run too long after the bearing was spun you will get metal pieces all through the engine, but I think you can just hot tank it or even clean it yourself.
Old Oct 28, 2005 | 04:42 AM
JimBlake's Avatar
Well, isn't it just dumb luck whether or not any metal shavings get into the head's oil passageways? Do ya feel lucky? I think I'd disassemble the head & make sure it's clean.
Old Oct 28, 2005 | 07:23 AM
zman's Avatar
Default Re: using a head from an engine that spun a bearing (JimBlake)
yeah, thats what i figured. For how little effort it would take to disassemble then assemble i think i am going to not take a chance.
Thanks guys
terrybogard21
Jul 30, 2009 06:32 AM
Stoich EG2
Oct 9, 2007 08:30 AM
11mastamind11
Nov 15, 2005 04:39 PM
hybrid_vtec
26
Jun 23, 2005 10:36 PM
sauceman
Feb 8, 2003 05:34 AM
