URGENT -- crower cam - degreeing
Old Feb 4, 2006 | 12:56 PM
c0nspire's Avatar
Default URGENT -- crower cam - degreeing
Hi
I need to know which cam lobe i use to degree off of.
its a 92-95 vtec d series cam, am i suppost to use the vtec lobe, intake, or exhaust?
hope somebody has an answer, thanks
Modified by c0nspire at 2:13 PM 2/4/2006
Old Feb 5, 2006 | 06:51 AM
NJIN BUILDR's Avatar
Default Re: URGENT -- crower cam - degreeing (c0nspire)
It matters which one you have the spec.s for.Crower has all their cam cards online if you don't have the spec.s.
Glenn
Old Feb 6, 2006 | 12:26 PM
bcborn's Avatar
Default Re: URGENT -- crower cam - degreeing (NJIN BUILDR)
Additional info on the boys behalf;
The cam specs for Crowers new D16Z6 turbo cam are not listed in their Cam Spec section of the web site.
63441ZT
Cam card for intake says 13deg BTDC at .050 lift but does not tell you which rocker - primary/secondary
In actuality the reading comes in at 22deg ATDC on the #1 primary intake retainer. Cam installed with #1 piston TDC and the keyway straight up, lobesdown. We are using the Edelbrock Cam gear which does not have the D16Z6 timing marks.
We pulled the rocker assembly off and degree'd off the mid lobe (VTec) and the numbers came in bang on at 13deg BTDC
Modified by bcborn at 4:22 PM 2/6/2006
Modified by bcborn at 5:48 PM 2/6/2006
Old Feb 6, 2006 | 09:37 PM
c0nspire's Avatar
bump
Old Feb 7, 2006 | 07:05 PM
bcborn's Avatar
Default Re: (c0nspire)
Found out measurements are taken at the retainer with the rocker locked up and operating off the VTec lobe.
Anyone have a secret here on how to lock the SOHC rockers besides the compressed air route.
Or if using the compressed air route some do's and don'ts.
Modified by bcborn at 6:16 PM 2/8/2006
Modified by bcborn at 12:46 AM 2/9/2006
Old Feb 8, 2006 | 05:16 PM
bcborn's Avatar
Default Re: (bcborn)
ttt
Old Feb 9, 2006 | 09:31 AM
bcborn's Avatar
Bump
ArniFPR
Oct 23, 2013 05:22 PM
50-50
Oct 23, 2009 01:40 PM
mike93boost
Apr 5, 2006 05:46 PM
