Unsolveable problem: Stutter / misfire
Old Sep 16, 2005 | 08:15 AM
  #26
Boosted Chemist's Avatar
Default Re: Unsolveable problem: Stutter / misfire (raene)
what happened with my bin ?
Old Sep 16, 2005 | 11:40 PM
  #27
raene's Avatar
Default Re: Unsolveable problem: Stutter / misfire (Boosted Chemist)
I can't get your bin to open correctly in Crome... just keeps ******* up I'm trying to make another right now!
Old Sep 17, 2005 | 06:38 AM
  #28
i made that in crome 1.8 idk if that maeks a differece?
Old Sep 17, 2005 | 10:17 AM
  #29
raene's Avatar
That's what I was using, Crome 1.1.8
The bin I made ran too lean, didn't get to test it. It needs tuning!
Old Sep 18, 2005 | 08:40 PM
  #30
n2oef's Avatar
have u checked plug gap yet?mine was breaking up at about 7 psi til i regapped plugs......
Old Sep 18, 2005 | 08:50 PM
  #31
raene's Avatar
Default Re: Unsolveable problem: Stutter / misfire (n2oef)
Well I finally got to run your bin Boosted Chemist, it runs a LOT better but it's still misfiring and has no power. It seems like it struggles to hit 3k rpm. The timing is like 6 degrees advanced from where mine was so I don't know how much more I'd want to advance it, though! Thoughts?
n2oef, plugs are gapped at 0.028". I've tried stock gap, no difference
Old Sep 19, 2005 | 06:15 AM
  #32
u want me to make a new base to go off of?
Old Sep 19, 2005 | 10:25 AM
  #33
raene's Avatar
Sure, if you feel like it!
You're using a b16 turbo on Crome right? Using 450cc injectors? If so maybe I could just try your bin.
Old Sep 19, 2005 | 10:34 AM
  #34
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">Sure, if you feel like it!
You're using a b16 turbo on Crome right? Using 450cc injectors? If so maybe I could just try your bin. </TD></TR></TABLE>
well im b16a turbo and using crome, but im also 9:1 and 880s, which are a pita to get to idle nice
Old Sep 22, 2005 | 11:03 AM
  #35
raene's Avatar
ttt for more ideas!
Old Oct 29, 2005 | 10:27 AM
  #36
raene's Avatar
ttt
Old Nov 3, 2005 | 08:52 PM
  #37
raene's Avatar
OK, I just used a test lead, wired a standard harness pin to one end and an ECU pin to the other end and literally bypassed the TPS wire and the MAP signal wire. No change. TPS and MAP power were both at 5V and the ground seemed good on each as well. So I doubt either of those are the problem.
Possibility of this being a mechanical issue. It only happens when the engine is maintaining speed or coasting down. It vanishes as soon as the engine is accelerating at a decent pace. You don't notice it in a parking garage but it becomes more noticeable in higher gears.
Old Nov 5, 2005 | 06:37 PM
  #38
mike93eh
Guest
Posts: n/a
i have the same problem in my 100% stock 90 crx....cant figure it out either..
Old Nov 5, 2005 | 08:55 PM
  #39
IntegraType-R's Avatar
uberdata blows..crome it.
Old Nov 5, 2005 | 10:16 PM
  #40
raene's Avatar
Default Re: Unsolveable problem: Stutter / misfire (IntegraType-R)
I'm converting to Crome shortly.
Any other ideas?
Old Nov 5, 2005 | 11:35 PM
  #41
Styler93GSX's Avatar
Do you have any way to datalogg.
Old Nov 7, 2005 | 05:47 AM
  #42
SOHFAST94's Avatar
Email me some pix of the plugs and your map. Stock ignition? Or CID?
Old Nov 7, 2005 | 08:54 AM
  #43
raene's Avatar
Default Re: Unsolveable problem: Stutter / misfire (Styler93GSX)
I have datalogged and while there were some spikes in the RPM trace, they had no correlation at all with the problem. I think they were just glitches in Uberdata. IAT, ECT, RPM and TPS were all logging just fine with no glitches other than the RPM randomly spiking.
SOHFAST, I'll email you some pics when I get home, thanks I've tried multiple maps and different injector CCs so I'll just email you the one I'm running right now with the 450s.
And yes, it's stock ignition with new plugs gapped at 0.028" and a brand new distributor.
Old Nov 15, 2005 | 06:14 PM
  #44
Where did you get the dizzy
Old Nov 15, 2005 | 07:42 PM
  #45
raene's Avatar
It's from a local company that manufactures them for the canadian market My brother's also using one on his LS/VTEC with no problems.
Old Nov 16, 2005 | 08:33 AM
  #46
havok hybrid's Avatar
I want to say. You NEED to try a different set of injectors.. I had this problem once.. redid everything.. still stumbled... then a new set of injectors.. and Bamm...it was fixed...
try it out.. see what you get .. looks like you have replaced everything but injectors. .. i bet one is dirty
Old Nov 16, 2005 | 09:10 AM
  #47
raene's Avatar
Default Re: Unsolveable problem: Stutter / misfire (havok hybrid)
I put my old 240cc injectors and my old 240cc map back in... same problem I've also checked the wiring to the injectors and resoldered... no change.
I'm freaking stumped. I'm considering replacing the entire wiring harness, interior and exterior, with a completely re-loomed and inspected replacement stock harness from a donor car, and getting an OBD0-OBDI conversion harness and just forgetting the whole thing. If I knew it was a harness problem, that is.
*edit* Can a resistor box go bad?? That's about the only part of the fuel system I haven't looked at/replaced.
Old Dec 10, 2005 | 12:06 PM
  #48
rebo0t's Avatar
I had the same problem last night. I searched and found your thread. The problem I'm having is the same as yours. It's only noticable at high gears and I have an LS/Vtec. I was on the freeway last night and around a steady 3.5-4k the car would slow down, lose power and hear a slight popping sound out my header back straight exhaust.
If I let off the throttle and get back on it, it'll disappear but come back after a minute. If I give it more gas, it also goes away and come back. There was one time where it started popping and I gave it more gas, it kept popping then suddenly power came back in and car started pulling. I cant explain this problem or think of whats wrong. I think its because theres too much timing. Or maybe a bit lean, but that does not explain how its just doing this On/Off thing.
Old Dec 10, 2005 | 12:11 PM
  #49
rebo0t's Avatar
Also, forgot to mention, when I heard it popping and gave it more gas.. The car would keep pulling until I stay at a steady RPM. Then you would hear a slight popping again.
Old Dec 12, 2005 | 12:24 AM
  #50
raene's Avatar
Default Re: (rebo0t)
Is yours a chipped ECU? How's the oxygen sensor... yours very much sounds like a blown O2
