unknown engine plug
Old Jun 20, 2002 | 08:55 PM
servion's Avatar
Default unknown engine plug
there is a plug on my civic ('97 cx) that I cannot for the life of my find a place to plug into anything. It's doen by where the o2 sensor is, right now its dangling right by the o2 sensor, and it has 3 wires (rectangular shaped plug). Any ideas on what it goes to?
I searched the motor for a place to plug it into, and I can't find anything. Hopefull this will solve my bad idle problem.
Old Jun 21, 2002 | 05:27 AM
vtecrx's Avatar
Default Re: unknown engine plug (servion)
did you get factory ac in your car? If not I have heard that some cars were already wired for ac hat did not come with it.
Andy
Old Jun 21, 2002 | 08:15 AM
servion's Avatar
Default Re: unknown engine plug (vtecrx)
It was a CX, so no AC at all. The plug is dangling under the car right by where the o2 sensor drops into the downpipe
Old Jun 21, 2002 | 08:55 AM
vtecrx's Avatar
what I am trying to say is that some civics that did not come with ac standard were still wired for ac to be added as a factory option. I guess it was an attempt to not fabricate different harnesses for different models. Just like some cars came wired for vtec when they had a non-vtec engine. If you have a meter try to check for continuity between the plug and the place where the fuse would plug into your fusebox if the car did come with ac. I have seen something similar to this before. It might also be a plug to hook up a diagnostic machine. I have only heard of this but never actually seen this plug. it is my understanding that those plugs will usually have some sort of rubber plug to pretect it. Have you also looked at your tranny?
Andy
Old Jun 21, 2002 | 09:06 AM
sgT's Avatar
sgT
if i remember right, the 96+ civics have a 3 wire Idle Air Control Valve plug
Old Jun 21, 2002 | 09:27 AM
Mikey3000's Avatar
does the plug have 4 holes but only 3 wires?
Old Jun 21, 2002 | 09:47 AM
servion's Avatar
Default Re: unknown engine plug (Boss Hogg)
nope... 3 holes and 3 wires
Old Jun 21, 2002 | 02:34 PM
Chiovnidca's Avatar
Does it come off of the engine harness or the body harness?
Old Jun 21, 2002 | 02:43 PM
servion's Avatar
Default Re: unknown engine plug (Chiovnidca)
engine harness
Old Jun 21, 2002 | 02:45 PM
servion's Avatar
Default Re: unknown engine plug (sgT)
well, I have a 2 wire plug to my IAC and if i pull it, the ecu throws an IACV code.
Old Jun 21, 2002 | 04:46 PM
Mikey3000's Avatar
hmm take can you take a pic of it? oh, is it your EGR plug? that's a 3 wire plug.
Old Jun 21, 2002 | 09:19 PM
Pengo's Avatar
is the open end or attached end of the plug close to the 02 sensor? any open plugs on ur tranny? i think VSS and back up light plugs are on there. pics would help alot
Old Jun 22, 2002 | 03:21 AM
TECH43's Avatar
Default Re: unknown engine plug (Pengo)
ckf smartguys (crankshaft fluctuation sensor) obd2/3...if you are running a 92-95 ecu...dont worry about it..if you are using a 96- ecu..then you need to use a 96- us oil pump/ckf sensor. b series ckf sensors have a two pin connector.. the civic uses a 3 pin connector..the 3rd pin on a civic is on for shielding..so dont use it..you can just snip it off...you wont need it...the color coding on a civic engine harness and a b series ckf sensor matches..so its a easy fix.
foxyroxy
Jun 8, 2011 08:31 PM
eghatchfla
Sep 15, 2010 06:21 PM
B20TRIZ
Mar 29, 2010 02:36 PM
EgK2o09
Jan 28, 2009 05:50 PM
EJ1 wilcox
21
Jan 7, 2008 11:49 AM
