universal O2 sensor
There should not be. However, I would not risk splicing the wire and reconnecting them. Current flow or ohm could change. In physics, current flow is comparable to water flow. Thinks about this comparision, I would not risk the lost of performance. I would get exact oem replacements.
I'm doing a obd0-obd1 conversion and the harness that is required doesn't have the factory 4 wire o2 sensor clip, so i'm going to have to cut and splice somewhere to convert the 1 wire to a 4 wire.
bam69icp
Oct 21, 2008 08:35 PM
