uneven drops
Old Jun 3, 2002 | 04:32 PM
redteg1's Avatar
Default uneven drops
i have eibach prokit on my gsr and i just noticed today that the driver side front is a bit lower than the passenger side and the passenger side rear is slightly lower than the rear driver side...wat is this from?! could this be normal? wat could've caused t his?
Old Jun 3, 2002 | 05:58 PM
redteg1's Avatar
Default Re: uneven drops (redteg1)
ttt
Old Jun 3, 2002 | 06:14 PM
dkay040's Avatar
how are ur shocks doing??
Old Jun 3, 2002 | 06:17 PM
redteg1's Avatar
Default Re: uneven drops (dkay040)
stock shocks on 1.5 in drop ...eibach prokit...have had them on for a while now but they're kinda sqeaky creaky over bumps
Old Jun 3, 2002 | 06:23 PM
dkay040's Avatar
maby there blown thats the only thing i can think of
Old Jun 3, 2002 | 08:20 PM
allmtr's Avatar
have you gained any weight lately?
Old Jun 4, 2002 | 02:37 PM
redteg1's Avatar
Default Re: uneven drops (allmtr)
yea 230lbs in 1 yr
Old Jun 4, 2002 | 05:52 PM
wuggiewuggie's Avatar
dood!!! i have the same freaking problem with my integ... i thought i put my car back together wrong or sumtin... the passenger rear wheel sits higher than the driver side rear wheel by like a cm or maybe a lil more. I just started noticing it. Now that you guys mentioned it i think my stock shocks are probably blown to hell and that mite be what's causing my problem. Haha... i've been driving my car slammed like 3.5 inches (lowest setting on the coilovers) for like 6k miles.
Old Jun 4, 2002 | 08:23 PM
khoalie's Avatar
Default Re: uneven drops (wuggiewuggie)
its probably caused by the fact that you usually drive alone in the car
the extra weight actually does make the driver side sag some.
my friends integra did this so we ended up just swapping the springs from one side to the other.
that way the other spring can 'sag' and they would eventually become even
my car did this too but all i had to do was crank the coilover up a little
Old Jun 4, 2002 | 08:31 PM
redteg1's Avatar
Default Re: uneven drops (khoalie)
well i don't have coilovers...bah
Old Jun 5, 2002 | 12:19 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
cars are not evenly balanced in weight, even w/out driver. adjust accordingly.
Old Jun 5, 2002 | 05:18 PM
khoalie's Avatar
Old Jun 12, 2002 | 02:48 PM
tonydatyga's Avatar
eww
realtalkjohnny
Honda Civic (2001 - 2005)
18
Jul 10, 2010 10:16 AM
b20acura
Sep 9, 2006 04:03 PM
iNetForce
Nov 10, 2004 03:20 PM
ravi
Jul 12, 2003 11:58 PM
SeaBass
May 26, 2003 07:34 AM
