underdrive pulley what do they do? are they worth getting?
Old Jan 15, 2003 | 06:14 PM
egturbo's Avatar
Default underdrive pulley what do they do? are they worth getting?
what the title says....
Old Jan 15, 2003 | 06:59 PM
Shawn C's Avatar
In The Garage
Default Re: underdrive pulley what do they do? are they worth getting? (egturbo)
they are a little bigger and run your accessories (alternator, P/S, and A/C) a little slower, freeing up some hp. yes they are worth it.
Old Jan 15, 2003 | 07:44 PM
tek_civic's Avatar
Default Re: underdrive pulley what do they do? are they worth getting? (22lbGS-R)
i have heard mixed results some say they really work others say they barely do. does anyone know of some dyno slips of these?
Old Jan 15, 2003 | 08:55 PM
90civichbsi's Avatar
Default Re: underdrive pulley what do they do? are they worth getting? (tek_civic)
i had one on my 90 civic for 2 years, i could tell a pretty good difference in power, as did one of my friends w/ a 93 accord
Old Jan 16, 2003 | 11:32 AM
Perfectionist's Avatar
They are actually smaller than stock. As a result, they spin your AC, alternator, PS pump, ect., SLOWER. IMO, not worth the hassle. Besides the expense, there's the chance of a constantly low battery because of insuficient charging from the alternator. As far as gains... you will notice a gain only because you spent the money. In the real world, I doubt it's very significant.
Old Jan 16, 2003 | 12:40 PM
Shawn C's Avatar
In The Garage
Default Re: underdrive pulley what do they do? are they worth getting? (Perfectionist)
<sighs> no, they are bigger. if they were smaller, they would spin accessories faster, in effect losing hp. the crank underdrive pulley is smaller, but not the accessory underdrive pulleys. they do make a difference, and every little bit helps. i just took off the P/S and A/C, and ran a UR (unorthodox racing) alternator underdrive pulley and a UR racing crank pulley(single belt, alternator only) I also had a HUGE battery in the back of my teg, an AC Delco 1000 cranking amp, and it always stayed fully charged, and ive never heard of anyones battery (in good condition) getting low.
[Modified by 22lbGS-R, 9:43 PM 1/16/2003]
Old Jan 16, 2003 | 12:54 PM
GruvyTune's Avatar
New User
i have one that i used in my 1995 integra. the car was stolen but the pulley (blue anodizing) is sittin in my garage if you are interested... $90 and its sold.
Old Jan 16, 2003 | 01:06 PM
You are correct, of course. The driven pulleys are larger. The crank pulley, what I was refering to, is smaller. BTW, there have been some posts regarding engine damage due to underdrive crank pulleys. Mostly due to harmonic vibrations. I have no direct experience with any underdrive pulleys, so I don't know how common the damage may be.
Old Jan 16, 2003 | 01:12 PM
Shawn C's Avatar
In The Garage
yeah i heard of the underdrive crank pulleys warping the crank an ****...... but i never had a problem, and i was making 409 hp, so i trust them.
Old Jan 16, 2003 | 01:17 PM
Desslok's Avatar
THe only thing i've personally seen is increased main bearing wear.
Chobits16
Oct 30, 2011 05:49 PM
Integraoligist
Nov 2, 2005 10:37 AM
deeksmooth
Oct 22, 2003 09:51 PM
Tyson
May 13, 2002 12:08 PM
