type R vs GSR suspension
Old Sep 15, 2004 | 04:38 AM
MikeGRIS's Avatar
Default type R vs GSR suspension
I know the rear lca on the Type R are different, is anything else different between the type R and a regular GSR?
Also what is the advantage of the Type R lca? I was thinking of upgrading my rear lca to type R when i get my Tein's. i did a little search but didnt really find anything.
Any info would help, thanks.
Old Sep 15, 2004 | 11:06 AM
MikeGRIS's Avatar
Default Re: type R vs GSR suspension (MikeGRIS)
No answers???? i know someone on here can answer this
Old Sep 15, 2004 | 02:43 PM
Launchpad's Avatar
Try a search
Old Sep 15, 2004 | 03:57 PM
MikeGRIS's Avatar
Default Re: type R vs GSR suspension (Launchpad)
are you trying to add to your number of posts or didnt you read the my first post???
Old Sep 15, 2004 | 06:29 PM
Launchpad's Avatar
Im just trying to add to my post count
Old Sep 15, 2004 | 10:14 PM
Kendall's Avatar
The stock Type R suspension uses shocks with a higher damping rate and slightly stiffer springs than the stock GSR. The Type R LCA's also change the rear suspension geometry slightly and non-Type R shocks are not compatible. If upgrading to the Type R LCA's, then you will also need to upgrade to at least a stock Type R suspension and any further shock/spring upgrades should also be for a Type R.
b18option
Suspension & Brakes
Mar 29, 2009 10:52 AM
fg2si!kid
Honda Civic (2001 - 2005)
Jan 22, 2007 04:54 PM
egb18c5
Dec 16, 2005 01:44 AM
opiumdaze
Sep 16, 2005 04:27 PM
ksoze1688
Sep 17, 2002 10:18 PM
