whats the difference? prop valves
i'm removing abs, i already have this prop valve so whats the difference between this and the 40/40 the 40/40
can i use the one i have already? (the top one)
Re: whats the difference? prop valves (BlueIntegraBoy)
You could use the 92-95 one but youll have to reroute your hardlines to fit them up. Easy thing to do is get a prop from the SI.
Re: whats the difference? prop valves (Chim Chim)
i know i'm in the civic/del sol section because thats the section i'm usually in but in this case i'm working on a 94 integra.. i am shaving the engine bay. i'm making all new custom lines anyways so it shouldnt matter then?
#1 Super Guy
Re: whats the difference? prop valves (2wheelhunter)
The one for an ABS system only has 4 ports on it. This is because the rear lines come straight out of the ABS unit, and pass through the valve.
The NON ABS valve has 6 ports. This is because two lines come from the master cylinder and go into the valve. Then the valve splits the two lines into 4 more that go to each wheel.
If your making new lines, then you wont' have any problems using the DC 4040 valve. Just make absolutely sure you get all 6 ports going to the right place. If you have the rear lines going to the front, your going to lock up one-or both rear brakes real quick. Also, the brake system is divided into two separate channels (LF/RR & RF/LR). If you get these mixed up, your bleed sequence will be off. So get it right the first time, and follow the bleed sequences of the NON ABS EG & DC...
Re: whats the difference? prop valves (94eg!)
thanks! i'v been doing plenty of research on this.. now my last question.. can i use the ABS Master cylinder and booster?
#1 Super Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2wheelhunter »</TD></TR><TR><TD CLASS="quote">thanks! i'v been doing plenty of research on this.. now my last question.. can i use the ABS Master cylinder and booster?</TD></TR></TABLE>
Yeah. The ABS master cylinder is designed to function like normal when the ABS system shuts down due to a problem...
You just cannot use a NON ABS master cylinder on an ABS brake system.
Spikes11
05-04-2004 08:41 PM
