Type R LSD ?
Old Jan 6, 2003 | 08:06 PM
JDM_JON's Avatar
Default Type R LSD ?
What are signs of a Type R LSD going bad? example...From shifting hard from first to second, no more wheel spin ? or could that be the clutch...? any help would be greatly be apprciated...
Old Jan 6, 2003 | 08:50 PM
Nameless RB26's Avatar
Default Re: Type R LSD ? (BucketDC2)
When your wheels spin, you're losing traction. Remember that!
The LSD's main purpose is to prevent wheel spin by transfering the right amount of power to BOTH wheels. Thus it is called "limited".
When you have a regular differential, the differential will transfer the torque to the wheel with the least resistance. That's why that wheel has a tendency to slip, and cause traction loss, which is what you DON'T want in a race, or anytime for all it really matters.
So if you're not getting wheel spin like you were before, you can't blame that on the LSD. If your LSD was broken, you would more than likely not even be able to drive the car.
If wheelspin is what you LIKE, then I would suggest a different clutch or some shitty tires.
Old Jan 6, 2003 | 09:03 PM
JDM_JON's Avatar
Default Re: Type R LSD ? (Nameless)
yea but the thing is that when i first put the tranny in it would have wheel spin...and both would sping...but i`m saying that it doesnt do it anymore....so i am wondering if it is the clutch or the LDS itself.....pretty much what i am asking is that would a worn out LSD unit have the same symtoms as of a worn out clutch ?? thanks again
Old Jan 6, 2003 | 09:15 PM
Have a friend watch your tires when you do a small burnout..
Pull the E-brake, and let them rip for a couple seconds..
I bet it's still working
Old Jan 6, 2003 | 09:17 PM
JDM_JON's Avatar
so most likely it is my clutch goin out ?
Old Jan 6, 2003 | 11:10 PM
JDM_JON's Avatar
anyone else have a thought on this??
Old Jan 7, 2003 | 12:02 AM
drjondurst's Avatar
What would his friend be looking for?
Old Jan 7, 2003 | 12:17 AM
Katman's Avatar
Well, you'll still be able to make the wheels burn out, if you did the e-brake thing, but in this case both should be spinning and not just one, since the LSD would in sense, be working.
I personally think your clutch could be going out if anything, before a gear type ITR LSD would go bad. It's rare to break an ITR LSD if you haven't lifted a front wheel while racing.
Old Jan 7, 2003 | 10:48 AM
JDM_JON's Avatar
Default Re: Type R LSD ? (Katman)..
yea...i think it is my clutch too....because i wouldnt think that the lsd would act like a slipping clutch...but yeah..its been buggin me...
Old Jan 7, 2003 | 12:01 PM
eg6ajk's Avatar
Default Re: Type R LSD ? (Katman).. (BucketDC2)
while back I cracked my LSD (in my B16A tranny), same torsen type of LSD as ITR.
basically the car becomes undriveable as the axles no longer get power transferred to them. the mainshaft, countershaft all spins with the ring gear but the diff doesn't distribute the power.
it feels like really badly slipping clutch(rpm rises but the car barely moves) in my case I just made it home (lots of downhill and coasting helped me)
(8k rpm in 2nd, while going only less then 25km/h)
you are most likly not getting any wheel spin as there isn;t enough power to brake the tires loose. LSD will not bias the power if one wheel has more then enough traction (at least not all of them)
Old Jan 7, 2003 | 09:52 PM
JDM_JON's Avatar
Default Re: Type R LSD ? (eg6ajk)
sounds so far that people are leaning more towards my clutch wearing out....i think it is too
Old Jan 7, 2003 | 11:35 PM
NiraCivicJDM's Avatar
what was the problem on that ? i once had a problem like that before, so i got a new tranny and clutch and i didnt bothered to get a research on that becaused i needed my car soon so i said fawk it and went and got a tranny and clutch the nextday
Old Jan 9, 2003 | 02:27 PM
JDM_JON's Avatar
Default Re: Type R LSD ? (NiraCivicJDM)
did u have an LSD tranny?
Old Jan 9, 2003 | 03:33 PM
10K2HVN's Avatar
speaking of ITR LSD tranny's does anyone have one of those for sell...?
Old Jan 9, 2003 | 07:22 PM
93b18civic's Avatar
Default Re: Type R LSD ? (10K2HVN)
b18c1_powered_si has an itr tranny
brendan427
Transmission & Drivetrain
10
Sep 7, 2012 01:58 AM
em1gangsta
Jan 24, 2008 11:20 PM
C5teg
Dec 21, 2007 01:17 AM
speedminded
Sep 5, 2004 06:26 PM
ls95hatch
25
Oct 3, 2003 10:48 PM
