Twm ITBS HELP
Old Jun 25, 2007 | 01:41 AM
eLS6uep's Avatar
Default Twm ITBS HELP
Hi Everyone I just got TWM ITBS put in my car today and im suffering someproblems....i cant seem too get the itbs too open fully, every thing hooked up right but every time i step on the pedal its just struggles?the tps is reading at 30% at full throttle on the pedal...checked all the vacuum lines and everything seems all fine...even tried playin with those metal sticks adjusting the butterfly..still nothing..but ever time i play with it the butterfly is never fully closed? any one got any ideas or tips too help me out? i even tried searching for help still no help?
well im running
b18cR Jap spec
Buddyclub headers
Toda A Cams
TWM itbs 2000 with stock injectors?
hondata s300
thnaks steven
Old Jun 27, 2007 | 11:01 AM
preludedriva's Avatar
Default Re: Twm ITBS HELP (eLS6uep)
is the tps sensor calibrating correctly?
Old Jun 28, 2007 | 02:00 PM
Rosko's Avatar
Default Re: Twm ITBS HELP (preludedriva)
sounds like the linkage may be way out of adjustment
Old Jun 28, 2007 | 04:12 PM
eLS6uep's Avatar
I seem too fix the problem with idling it drives smoothly now...i just cant get the throttles too open 100% max it will go when hitting the floor is 38%? is there a way too adjust it soo i can get 100% throttle...o and the tps reading is fine...
Old Jun 28, 2007 | 04:35 PM
mmuller's Avatar
Mad Scientist
so are you saying that the throttle plates are not actually opening or that tps reading % is wrong?
are the itbs synch'ed?
if your throttles are mechanically not opening, and if there is no obstruction on the cable movement; your actual cable length is at fault
how far do you have to push the gas pedal before the throttles open?
Old Jun 28, 2007 | 05:16 PM
eLS6uep's Avatar
Default Re: Twm ITBS HELP (mmuller)
well it opens right away,i have like around 15cm b4 the pedal hits the floor...and the tps is reading 0% at no throttle so that seem right..wen the pedal too the floor it reads 38%...wen lookin at the throttle bodies they arent fully open...and yes the throttle bodies are sync..and the cable length is fine i just cant seem too make it open 100%
Old Jun 28, 2007 | 05:40 PM
mmuller's Avatar
Mad Scientist
can you manually open the throttle bodies?
Old Jun 28, 2007 | 05:42 PM
eLS6uep's Avatar
yea i can open the throttles normally....it opens all the way but i cant seem too open it with the p[edal
Old Jun 28, 2007 | 05:51 PM
Rosko's Avatar
can you post a pic? it sounds like the diameter of the throttle rotor is too big.
a smaller rotor will open faster than a larger one because of the smaller circumferance that the cable has to wrap around.
Old Jun 28, 2007 | 05:56 PM
eLS6uep's Avatar
ummm i try post a pic 2mmrrow....with the rotor thing its the one that came with the itbs? is there anyway of getting a smaller rotor for it? thanks
Old Jun 28, 2007 | 06:19 PM
Rosko's Avatar
Default Re: (eLS6uep)
Now that I looked at a picture on their site I think that the rotor deal is ok, its big but they compensate for it in their linkage.
I guess I would try to contact TWM, I'm sure the issue has prolly came up before.
Old Jun 29, 2007 | 11:20 AM
mmuller's Avatar
Mad Scientist
Default Re: (Rosko)
if you disconnect the throttle calbe from the pedal; can you open the itbs all the way?
Old Jun 29, 2007 | 07:30 PM
eLS6uep's Avatar
Default Re: (mmuller)
yea it can be open all the way...my friend got it too open too 60% and told me that my pedal travel too short he goes if i want too go 100% i should make my pedal travel longer? is there any other way cause im stumped..and its starting too annoy me...
Old Jun 29, 2007 | 10:04 PM
EVLTEK's Avatar
sounds like the cable is just too long....your pedal should not have to travel any further then it does standard for them to work.
Old Jun 30, 2007 | 06:43 AM
rmcdaniels's Avatar
I had the same problem, JDogg reached down into the driver-side footwell and bent the gas pedal back upwards a bit, problem fixed. The stock pedal travel wasn't enough to open them all the way. You do need to recalibrate the TPS in your tuning SW as well, but that got them to open all the way.
Old Jul 5, 2007 | 03:25 AM
barefootbonzai's Avatar
that's some fucked up ****, still not fixed
Old Jul 20, 2007 | 09:50 AM
D-Rob's Avatar
Default Re: (barefootbonzai)
I had to cut the pedal-stop on the floor in order to go over 78%.
- Derek
eg:R
Jul 6, 2012 04:59 PM
appelsos
Jul 27, 2011 05:29 PM
eg6madness
Engine Management and Tuning
Jun 19, 2010 06:09 AM
TeknikDC2
Mar 6, 2005 06:30 PM
