turn signal relay conversion???
Old Sep 30, 2001 | 07:49 PM
John's Avatar
New User
Default turn signal relay conversion???
Since I installed my Wings West big mouth front bumper, I no longer have the bumper lens on my car. As a result, my electrical system detects a non-Honda-spec impedence, and my turn signals blink fast (kinda like when a turn signal bulb goes out, your turn signal will be faster to let you know you need to check a bulb). Somehow I've tolerated this annoyance for the past 18 months... but my tolerance is at an end.
Does anyone have an idea on how I can remedy this problem?
I did have one thought that might work. Replace my turn signal wiring and relays with those from a 5th generation Civic (think 91-95)... Since 5G Civics only have the corner lens, the relays wouldn't be looking for another set of bulbs.
Any ideas people?
Old Oct 1, 2001 | 02:41 PM
allmotorEG-SI's Avatar
Default Re: turn signal relay conversion??? (DunReit)
can't you just reinstall all the wireing and lighting and than tuckit away somewhere outasight. That way the computer will stil go"oh ok there is still lights there" but you just won't see them anywhere.
Old Oct 1, 2001 | 05:14 PM
John's Avatar
New User
Default Re: turn signal relay conversion??? (CAMAROCRUSHER)
i could do that, but at night it'd be wierd seeing a random glow from behind the bumper or what not....
Old Oct 1, 2001 | 06:09 PM
t's Avatar
t
you could meausre the resistance of the bulb and get a resistor put in its place
Old Oct 1, 2001 | 06:21 PM
John's Avatar
New User
Default Re: turn signal relay conversion??? (t)
i'll have to check on that, unless anyone knows the resistance offhand? is the resistance info available in a Helms manual?
TimVanScyoc
Mar 31, 2017 03:22 AM
jhammond_82
Jan 31, 2009 08:11 AM
