turn signal issue
My turn signals are not working for some reason. When I flip the sidemarker switch, the green blinkers don't flash or make noise either. But when I press the hazards, everything blinks and flashes as it should. I put in a new fuse of another amperage cuz its all I had around at the moment. Cud the problem be something else besides the fuse.?
Do you think the switch is bad or could it be anything else besides the fuse, because I changed the fuse with the correct amperage and it still doesn't work.
i changed the turn signal switch, the hazard switch, the relay, the fuse, i circuit tested the ends of the wire where the bulbs are and there is no sign of power. Im starting to think that the wire is fried. Is there a way I can replace the turn signal wires without removing the dash?
__________________
__________________
You will need to pull the hazard switch to test it, power for both the hazards and the signal lights go through the hazard switch.
Test for power, [12V+] at the yellow/black lead going to hazard switch, [ign. switch on].
If good, test for power at the green/orange lead at hazard switch, [ign. on, hazards off].
If good, test for power on green/orange at combination light switch. 94
Wiring after hazard switch is common for hazards and signal lights, so if hazards work, that wiring is not an issue. 94
stinkypinky1011
21
Nov 11, 2013 11:18 PM
