Tuning after compression and displacement change
I have removed the stock B17A1 motor from my car and built an 8.8:1 compression b18c1 to replace it. I can not afford the turbo kit yet, however I need to get the car back on the road. Is safe to assume that the factory map is safe with this setup? I will be using the stock OBD-1 ecu with the engine.
The factory map should be fine. You may want to advance the timing a bit and probably lean it out to get the most power out of it, or at least tinker around with that stuff. But stock settings it should run just fine.
99blackdc2
Sep 4, 2006 07:47 PM
NotPhilTran
Mar 17, 2005 05:40 AM
