are my bearings bad??acl's
Old 02-09-2007, 01:16 PM
eg:R's Avatar
Default are my bearings bad??acl's
started my car up in the morning and heard a rod bearing knock sound coming from the middle section of the block. the clicking sound seem to be more in the back of the block underneath the intake man. here are some pictures of rod 2 and 3 caps w/ acl bearings. just wondering if this was causing the noise. also found the rods and main bearings looking the same as these also.
[IMG][/IMG]
Old 02-09-2007, 04:04 PM
eg:R's Avatar
nobody
Old 02-09-2007, 05:28 PM
tha_badguy's Avatar
im no expert but look at the top of the 2nd bearing in paticular...
and up & down that one looks like it was touching the crank
galling?
Old 02-09-2007, 05:55 PM
eg:R's Avatar
Default Re: (tha_badguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy &raquo;</TD></TR><TR><TD CLASS="quote">im no expert but look at the top of the 2nd bearing in paticular...
galling?</TD></TR></TABLE>
what is the crank galling?
Old 02-09-2007, 08:31 PM
89s1's Avatar
Default Re: (eg:R)
actually looks like a hair or some other foreign stuff embedded in the bearing material. (the bearing on the right in the pic)
Old 02-10-2007, 08:10 AM
tha_badguy's Avatar
check the clearances...
Old 02-10-2007, 10:07 AM
eg:R's Avatar
the block was plastigauge to specs
Old 02-10-2007, 10:47 AM
DonF's Avatar
Default Re: (eg:R)
Those look like heat check marks. Not enough oil volume or too tight a clearance. Probably the later.
ceearexx
02-04-2014 05:31 PM
SuckMyDOHC
06-15-2008 11:29 AM
eg:R
02-11-2007 09:53 AM
Sinner
12-25-2004 05:05 PM
hksbigboi4
04-16-2004 07:48 AM
Quick Reply: are my bearings bad??acl's
