trimming polyurethane....
Old Jun 2, 2003 | 09:49 PM
COMplex.'s Avatar
Default trimming polyurethane....
i need to make a bushing.
so if i order some polyurethane 1.5" x 6" rod, can i just use regular tools?
i need to drill a hole in the middle, and it needs to be about .5" tall and about the size of a quarter.
so how can i trim the polyurethane rod?
please say a drill and saw will work. lol
thanks
(btw: i will measure the exact size i need before i cut of course, i just need to know what to buy to cut it)
Old Jun 2, 2003 | 10:06 PM
4DeepCivic's Avatar
Default Re: trimming polyurethane.... (john.fuggi)
Hope all your tools are sharp.
Old Jun 3, 2003 | 08:55 AM
COMplex.'s Avatar
Default Re: trimming polyurethane.... (4DeepCivic)
does that mean its going to be hard? lol
Old Jun 3, 2003 | 12:45 PM
PupaScoopa's Avatar
Drill a hole in the middle. Put a bolt through it and tighten it with a nut. Now insert the bolt into a drill and turn the urethane against the wheel on a bench grinder or sander until you remove enough material. Measure each end as you go so one side isn't bigger than the other.
You may be able to (get someone to) turn it on a lathe for you as well.
Old Jun 3, 2003 | 08:38 PM
COMplex.'s Avatar
Default Re: trimming polyurethane.... (PupaScoopa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PupaScoopa &raquo;</TD></TR><TR><TD CLASS="quote">Drill a hole in the middle. Put a bolt through it and tighten it with a nut. Now insert the bolt into a drill and turn the urethane against the wheel on a bench grinder or sander until you remove enough material. Measure each end as you go so one side isn't bigger than the other.
You may be able to (get someone to) turn it on a lathe for you as well.</TD></TR></TABLE>
best idea EVAR! thanks. never thought of that. didn't know how i was going to get it perfectly round!
migs
Feb 11, 2008 08:07 AM
vtec.dc2
Apr 24, 2007 09:43 AM
HamiltonRex
Mar 27, 2005 07:37 PM
Sephro
Apr 26, 2004 07:34 AM
c1civic
11
Oct 22, 2003 11:21 AM
