Tricking O2?.....
Old Sep 19, 2004 | 11:19 PM
GDM Z28's Avatar
Default Tricking O2?.....
Ok....my friend is going to be boosting his GF's 96 Honda civic EX. We have everything planed out (he is making the manifold, DP, exhaust, charge pipes, and everything else). It will be running the hack (i hate it but this is a budget set up) and maybe later on down the road the MSD BTM unit. But for not we were talking about either making a test pipe, or gutting the stock cat. But then we were thinking since its obd2 its going to throw a CEL. Now i was thinking if we make a test pipe and leave the secondary O2 outside of the exhaust system (leave it hanging in the engine bay or down under the car) it will read cleaner air than the primary so it will think the cat is working, right? Since its a narrow band i wouldn't think that it could tell its perfect air but it will just think its cleaner. Has any one tried this? Does any one think this will work? Please post any thing that will help us with this dilemma. TIA...
-Trent
Old Sep 19, 2004 | 11:24 PM
8200RPM's Avatar
local hippie
Default Re: Tricking O2?..... (civicflnum1)
<--- girlfriend.
TIA for any help
Old Sep 19, 2004 | 11:56 PM
honda_power69's Avatar
Default Re: Tricking O2?..... (8200RPM)
No, the O2 sensor is designed to read just that, O2 (or oxygen). If you leave it outside, in the air (oxygen) it will most definately throw a code.
If you really want to do this, heres a link to a cheap fix: http://www.mkiv.com/techarticl...ator/
Old Sep 20, 2004 | 12:03 AM
GDM Z28's Avatar
Default Re: Tricking O2?..... (honda_power69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_power69 &raquo;</TD></TR><TR><TD CLASS="quote">No, the O2 sensor is designed to read just that, O2 (or oxygen). If you leave it outside, in the air (oxygen) it will most definately throw a code.
If you really want to do this, heres a link to a cheap fix: http://www.mkiv.com/techarticl...ator/</TD></TR></TABLE>
But if its designed to read oxygen and its outside getting alot of it why would it throw a code?
Old Sep 20, 2004 | 12:05 AM
Because it's going to tell the computer that theres an excessive amount of air "in the exhaust" and to richen things up to compensate for it (i.e. CEL and car runs like ***). It's also going to think there is something wrong with the cat with that much extra "air inside the exhaust system".
Old Sep 20, 2004 | 12:10 AM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_power69 &raquo;</TD></TR><TR><TD CLASS="quote">Because it's going to tell the computer that theres an excessive amount of air "in the exhaust" and to richen things up to compensate for it (i.e. CEL and car runs like ***). It's also going to think there is something wrong with the cat with that much extra "air inside the exhaust system".</TD></TR></TABLE>
i got ya i see its supose to see between .4 and like .6 volts or something like that......ty for the link!
Old Sep 20, 2004 | 01:43 AM
No problem, hope that helps a little
Old Sep 20, 2004 | 10:47 AM
GDM Z28's Avatar
Default Re: (honda_power69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_power69 &raquo;</TD></TR><TR><TD CLASS="quote">No problem, hope that helps a little </TD></TR></TABLE>
it does thank you for the link. BTW i saw your sig if you need help with uberdata pm me...im running it so maybe i can help you.
Old Sep 20, 2004 | 10:50 AM
8200RPM's Avatar
local hippie
Yes it was very helpful and interesting read. thanks
HatchBlakKidd
Sep 30, 2011 07:40 AM
732xghost
Feb 17, 2007 02:23 PM
MaGoodc2
Feb 18, 2006 02:53 PM
Azn Kenny
Oct 11, 2005 05:14 PM
Betsie 99'
Jul 15, 2002 11:22 AM
