obd2b to obd1 help
Old Apr 30, 2005 | 05:14 PM
THE LORD OF CHAOS's Avatar
Default obd2b to obd1 help
i going to want to boost my 2000 ls in the near future and i want to tune it with uberdata or hondata, but my car has that stupid immobilizer integrated in the key. if i do a changeover to obd1 will this screw up the immobilizer so i cant start the car? how can i remove it or get around it? is it a separate module, or is it directly integrated inside the ECU? thanks.
Old Apr 30, 2005 | 07:35 PM
Kendall's Avatar
The immobilizer is in the stock ECU. If you replace the ECU with an OBD-1 one, then you will no longer have an immobilizer.
Old May 1, 2005 | 11:15 AM
Default Re: (Kendall)
awesome, that is what i needed to know. thanks
Old Jul 4, 2005 | 01:42 PM
Vera's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">The immobilizer is in the stock ECU. If you replace the ECU with an OBD-1 one, then you will no longer have an immobilizer.</TD></TR></TABLE>
i thought the immboilizer had to do with the ignition and not the ecu ?
Old Jul 4, 2005 | 11:00 PM
NSXtcy21's Avatar
the ecu is what actually houses the immobilizer chip.. theres also a immobilizer box on the ignition.. but when you remove the ecu.. the new obd1 ecu wont look for that ignition immobilizer.
Old Jul 5, 2005 | 01:27 PM
Vera's Avatar
Default Re: (NSXtcy21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NSXtcy21 &raquo;</TD></TR><TR><TD CLASS="quote">the ecu is what actually houses the immobilizer chip.. theres also a immobilizer box on the ignition.. but when you remove the ecu.. the new obd1 ecu wont look for that ignition immobilizer.</TD></TR></TABLE>
oh **** .. hah cool .. the more i know
Old Jul 5, 2005 | 01:34 PM
2G0S0R1's Avatar
New User
100% correct. I at one time had the same question.
gabrielsousa
Engine Management and Tuning
Nov 11, 2014 12:16 PM
Ek9_Cuhzz
Northwest (Sales)
Jul 15, 2010 12:07 PM
Jap_Spec_Imports
Aug 10, 2009 07:11 PM
dkrex001
Oct 25, 2006 02:09 PM
