transmission problem?
Old Aug 17, 2004 | 07:36 PM
f15man's Avatar
Default transmission problem?
I recently bought a 1988 Accord and I am having problems shifting into reverse and 1st gear. It sounds like it is grinding. It is difficult to get the stick out of reverse also. It worked fine when I bought the car three days ago. Everything works fine when I am driving the car, but it only happens when I am at a dead stop. Any experience with problems like this? Thanks
Old Aug 20, 2004 | 12:52 AM
awdlaunchmonster's Avatar
Default Re: transmission problem? (f15man)
Sounds like it could be your shifter bushings. If you shifter is not lining up properly then its not pulling at the right angle to get the tranny out of gear. Check the bushings at each end of the shifter linkage for excess play.
Old Aug 20, 2004 | 07:03 AM
Paulnsx's Avatar
lemon law i would go talk to whoever you bought it from, make them fix it or make them give you back your money via the lemon law.
edit... i mis read the year as 1998 before... so this prolly isnt a real option
Modified by Paulnsx at 11:59 AM 8/20/2004
EF9_TryMe
11
Nov 14, 2008 12:02 AM
spintboy
Feb 1, 2008 09:01 AM
90dxhatchback
Jun 29, 2005 05:50 PM
CaTiRo
14
Sep 1, 2004 05:55 PM
