Transmission issues...
Old Jul 15, 2008 | 03:56 PM
DrewMD's Avatar
Davis Photography
Default Transmission issues...
I took my spare S20 tranny I had and tore it apart to replace the Input Shaft Bearing. I get everything put back together, case and all, and I check the gears. I can get into every gear including reverse but not fifth. So I thought, maybe you need to spin the spline to ease it into gear. Well I can't spin it at all no matter if I'm in neutral or in a gear.
What could be the issue here?
Old Jul 15, 2008 | 05:17 PM
khooper's Avatar
Default Re: Transmission issues... (DrewMD)
I had the same problem, and according to a tech bad motor mounts will cause strain on the shift linkage and 5th gear assy to wear out prematurely. Causing the dreaded 5th gear pop out.
_______________________
Heard what happen at Autopartswarehouse.com
Drive Safely and Smile Freely
Old Jul 15, 2008 | 06:22 PM
DrewMD's Avatar
Davis Photography
The tranny is still out of the car. I can spin the shaft but its VERY hard to. takes two hands.
Is this natural?
Old Jul 22, 2008 | 11:48 AM
DrewMD's Avatar
Davis Photography
BUMP
Old Jul 23, 2008 | 06:55 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (DrewMD)
no, it is not normal.
Open it back up, or have someone else do it for you.
CubbyChowder
Jun 1, 2010 04:44 PM
crxmex
Nov 4, 2007 01:33 AM
systemoverload
Jun 2, 2006 10:50 PM
FIxALPHA
Sep 10, 2003 04:47 PM
b00stn
Oct 25, 2002 02:22 PM
