Transmission issues...
Davis Photography
I took my spare S20 tranny I had and tore it apart to replace the Input Shaft Bearing. I get everything put back together, case and all, and I check the gears. I can get into every gear including reverse but not fifth. So I thought, maybe you need to spin the spline to ease it into gear. Well I can't spin it at all no matter if I'm in neutral or in a gear.
What could be the issue here?
I had the same problem, and according to a tech bad motor mounts will cause strain on the shift linkage and 5th gear assy to wear out prematurely. Causing the dreaded 5th gear pop out.
_______________________
Heard what happen at Autopartswarehouse.com
Drive Safely and Smile Freely
