transmission fill plug wont remove, help!
Old Mar 29, 2008 | 02:32 PM
ECHO74922's Avatar
Default transmission fill plug wont remove, help!
Have used all resources to remove this bolt and it has resulted in stripping it. Only thing to do would be to remove the transmission and drill bolt out. Any help for a better alternative would be appreciated, dont want to deal with the time and pain of removing the trans.
Old Mar 29, 2008 | 04:38 PM
Turbo B18C EJ6's Avatar
Default Re: transmission fill plug wont remove, help! (ECHO74922)
What kind of transmission do you have? im assuming a manual trans. if you cannot remove the plug you can just remove the vehicle speed sensor and fill the trans through that hole.
Old Mar 29, 2008 | 07:35 PM
ECHO74922's Avatar
im glad i ask before i removed the tranny, thx man you saved me the pain, i assume this will work for ef with speedo cable?
Old Mar 29, 2008 | 11:17 PM
fourthgenhatchB17's Avatar
Default Re: (ECHO74922)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECHO74922 &raquo;</TD></TR><TR><TD CLASS="quote"> i assume this will work for ef with speedo cable?</TD></TR></TABLE>
Yes. If it still has the d series trans, i believe 1.9 qts is the fill spec.
The beauty and function about using the actual fill plug is the ability to know the trans has the proper amount of fluid, assuming the vehicle is level. Remove the fill plug and fill with oil until it seeps out, then reinstall the plug. When filling thru the speed sensor hole, you can easily overfill.
Old Mar 30, 2008 | 06:06 AM
mmuller's Avatar
Mad Scientist
fill the tranny through the vss
Old Mar 30, 2008 | 01:21 PM
RedlinedVTEC's Avatar
Default Re: (mmuller)
Now you know always loosen the fill plug before the drain plug.....
meavey3368
Jul 12, 2014 11:29 PM
D7KWagon
Jun 14, 2014 01:08 PM
wiZCo
Aug 23, 2006 02:24 PM
Edwardo911
30
Sep 10, 2004 01:43 PM
