transmission.....
Old Feb 16, 2006 | 10:05 PM
qik_g_tre5's Avatar
Default transmission.....
whats up guys? my friends and i were having a debate about transmission compatabilty.....and here it is.....
Will a B16 tranny fit on a GSR motor? if so, how much work would be required and is this even a smart move to make?
Old Feb 17, 2006 | 05:28 AM
Lsos's Avatar
Default Re: transmission..... (qik_g_tre5)
I understand that all b-series transmissions are compatible.
Old Feb 17, 2006 | 07:32 AM
Honda Sport's Avatar
straight bolt on, no need for modification.
Old Feb 17, 2006 | 09:37 AM
Lsos's Avatar
Default Re: (Honda Sport)
You might want to look into the clutch though...I don't believe all the clutches match all the transmissions.
Old Feb 17, 2006 | 09:40 AM
forgot to add but it also depends on whether the tranny is hydraulic or cable.
Old Feb 17, 2006 | 10:39 AM
msmotorsports's Avatar
Hydro trannies are commonly called big shaft due to the main shaft having larger splines (about 1mm). Cable trannies are small shaft and require a different clutch.
toolbox21
Oct 21, 2009 03:24 PM
strawberry
Jan 11, 2008 02:34 PM
Damills
Feb 15, 2007 03:32 PM
turbo_ef9
Sep 6, 2004 05:12 AM
skribblah
Jul 9, 2003 07:23 PM
