trans question
Old Oct 22, 2007 | 05:17 PM
92hatchboi's Avatar
Default trans question
my trans was just freshly rebuilt. before i installed it, it went into all of the gears. and when i first put in on the car it went in all of the gears except 5th. now its hard to go into all of the gears. and the car acts like it wants to take off in neutral (well atleast it appears to be in neutral when i shift it). and this is the same problem i had on the previous trans before i took it out. do you think that it may be the shift linkage is bent?
by the way its a jdm b16 trans with a jdm type r lsd and final drive
Old Oct 22, 2007 | 06:44 PM
so lazy's Avatar
Default Re: trans question (92hatchboi)
are you sure you installed the clutch kit right? maybe it was over torque'd I had this problem with a car before a kid installed his own clutch and all the gears started to take alittle more push than usaual to engage. it ended up being that he used a air ratchet to install the pressure plate and over torque'd.
Old Oct 22, 2007 | 06:48 PM
92hatchboi's Avatar
Default Re: trans question (so lazy)
it ran through all the gears fine tho
Old Oct 22, 2007 | 06:51 PM
so lazy's Avatar
yeah this kid his car ran fine than 3hrs later he said he started to act up. he brought it to me come to find out the clutch was over tighten. i'm not saying this is your problrm im just giving you possible reasons.
Old Oct 22, 2007 | 07:02 PM
92hatchboi's Avatar
this is the same problem i had previously before i replaced the trans with the one i am running now
Old Oct 22, 2007 | 07:04 PM
so lazy's Avatar
change that clutch out or retorque it
Old Oct 22, 2007 | 07:18 PM
92hatchboi's Avatar
its a new clutch (ACT 6 puck and pressure plate), new flywheel(fidanza), new throwout bearing and new pilot bearing, i replaced all of these when i replaced the trans
Old Oct 23, 2007 | 07:44 PM
so lazy's Avatar
take it out.. and install it using a torque wrench...
Old Oct 25, 2007 | 06:50 PM
92hatchboi's Avatar
i just swapped the shift linkage and i still have the same problem. could a bad throwout earing be a problem. im all out of ideas
Old Oct 25, 2007 | 09:23 PM
dtapia's Avatar
well from what your describing i bet you had a bad disk .
Old Oct 26, 2007 | 04:23 AM
92hatchboi's Avatar
Default Re: trans question (dtapia)
its a new disk. my previous transmission did the same thing. that was the whole purpose of changing the transmission.
AcuraTeg32
Transmission & Drivetrain
Dec 16, 2012 07:30 PM
ohsnapzafingcu
10
Dec 13, 2010 06:44 AM
92hatchboi
Oct 22, 2007 05:52 PM
BHOP92
Apr 30, 2006 10:40 AM
AVATAR
Aug 23, 2004 03:13 PM
