TRANNY REBUILD
Old Aug 29, 2006 | 10:56 AM
No2Pencil's Avatar
Default TRANNY REBUILD
name some shops on the east coast that are good for rebuilding B trannys for a good price... thanx
Old Aug 29, 2006 | 11:32 AM
Flexmyrex's Avatar
Default Re: TRANNY REBUILD (No2Pencil)
what needs to be done to the trans?
Old Aug 29, 2006 | 12:50 PM
Runnerdown's Avatar
I rebuild d and b transmissions, what is the problem with it.
Old Aug 29, 2006 | 11:01 PM
No2Pencil's Avatar
Default Re: TRANNY REBUILD (Flexmyrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flexmyrex &raquo;</TD></TR><TR><TD CLASS="quote">what needs to be done to the trans?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">I rebuild d and b transmissions, what is the problem with it.</TD></TR></TABLE>
the 3rd 4th and 5th gear need to be replaced... and all new syncros from what i can tell.
3 and 4 slipes out while cornering and low excell.
grindes 3-5
5th gear is chiped and skipes teath
how much for work?
Old Aug 29, 2006 | 11:03 PM
No2Pencil's Avatar
"BOOST... no money for food"
lol, i like that
Old Aug 30, 2006 | 05:46 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
what kind of transmission is it? i can do it no problem, but you would have to ship it to me.
Old Aug 30, 2006 | 05:20 PM
No2Pencil's Avatar
Default Re: TRANNY REBUILD (not so civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not so civic &raquo;</TD></TR><TR><TD CLASS="quote"> i can do it no problem, but you would have to ship it to me. </TD></TR></TABLE>
thanks but the shipping would cost a grip + i gotta pay you too :/ if i took it out i would try to rebuild it my self bit i dont have tools for either
Old Aug 30, 2006 | 05:21 PM
No2Pencil's Avatar
i'd drive it tho... how much would you charge me?
Old Aug 30, 2006 | 08:01 PM
Craigp23usa's Avatar
it sounds like you have exsessive shaft play to me. mikght just be a bearing problem. i have been through that before.
the engagement falls out of the sleeve with to much play.
Old Aug 31, 2006 | 04:42 AM
No2Pencil's Avatar
Default Re: (Craigp23usa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Craigp23usa &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like you have exsessive shaft play to me. mikght just be a bearing problem. i have been through that before.
the engagement falls out of the sleeve with to much play.</TD></TR></TABLE>
you got it that sounds like me... my shifter feals like **** and theres a bump fealing spot in between the gears.
Old Aug 31, 2006 | 08:25 AM
yes. also...if it pops out of gear and the shifter does not seem to move to neutral...then you know it is excessive shaft play.
Old Aug 31, 2006 | 10:06 AM
No2Pencil's Avatar
cool man thanks... how much would you pay someone to rebuild it? is it a real pain in the *** to do?
Old Sep 1, 2006 | 06:55 PM
well the first step would be cracking it open and seeing what you have. if it is the mainshaft the fix is easy and will cost about 100 $. the bearings shipping might be expensive because they come from new york. at least the tranny side main will. this is hot a universal bearing either. you should check out gear speed too and give them a call n prices. they are very helpful.
i would say if u brought it to someone (tranny) it wil be a bit pricey.
try to find someone on here to do it.
I heard of people doing it for around 100 plus parts. worth it.
Old Sep 1, 2006 | 08:35 PM
ALL IMPORT's Avatar
well first thier are a number of problems u have so it sounds to me u need a complet overhaul from what u are saying but u never know the whole truth till u get into the trans. falling out of gear could be shaft play but i would say its your gears are worn out so bad it just dont hold anymore. or thiers a ring next to the syncro that holds the sleeve in position & it could have broke of even worn down also.
i see your in va. so your a little far away from unfortunatly. im in west palm fl.
i can tell u this. 3rd/4th are sold as a set with syncros hub ect. retail at $290 from dealership shop price is around $250
5th/reverse arer also sold as a set & it will cost around the same.
lucky for u 1st/2nd are on the counter shaft & u might not have to touch that shaft.
i can tell u this dont take your car to a domestic shop. u will regret it.
Old Sep 3, 2006 | 11:49 AM
No2Pencil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Craigp23usa &raquo;</TD></TR><TR><TD CLASS="quote">you should check out gear speed too</TD></TR></TABLE>
yeah i took a look at there sight and it has some nice stuff... it sounds like if i want it overhalled in VA its gunna cost me.
thanks for the help Craigp23usa when i get this thing settled out ill tell you guys the way i went and costs... i hope i dont get taxed hard
lol, yeah no domestic shops... they always look confused when i lift the hood.
vtecislife
Sep 2, 2008 08:45 AM
superhatchbackbros
10
May 30, 2006 10:19 PM
slammin86
Oct 19, 2004 04:38 AM
SupaFly_Honda
Oct 8, 2003 06:55 PM
MachAF
Jul 20, 2003 04:22 PM
