How can I fix a grind in Third gear?
Old Oct 8, 2003 | 04:47 AM
SupaFly_Honda's Avatar
Default How can I fix a grind in Third gear?
I got a b16 tranny and it has a grind in third gear. What can I do to fix it?
Old Oct 8, 2003 | 05:36 AM
Blaze45's Avatar
Brrraaaap!
Default Re: How can I fix a grind in Third gear? (SupaFly_Honda)
Rebuild your tranny. OR spend $30 on 3 qrts of GM Syncromesh. It has helped my 5th gear grind. You can only get it at the GM dealer. There is some knockoff but I cant remember what it is. Use the search for GM Snycormesh. It seems to be working well for most people with grinds.
Blaze
Old Oct 8, 2003 | 07:15 AM
pro1342's Avatar
Overhaul the tranny and replace the necessary gears and synchros.
Old Oct 8, 2003 | 08:14 AM
T4eg's Avatar
Default Re: (pro1342)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro1342 &raquo;</TD></TR><TR><TD CLASS="quote">Overhaul the tranny and replace the necessary gears and synchros.</TD></TR></TABLE>
Old Oct 8, 2003 | 08:45 AM
whatVTEC's Avatar
Default Re: How can I fix a grind in Third gear? (Blaze45)
Anyone know the part# for that GM syncromesh?
Old Oct 8, 2003 | 01:55 PM
Waachback's Avatar
Default Re: How can I fix a grind in Third gear? (whatVTEC)
#12345349 and #12377916
Old Oct 8, 2003 | 02:44 PM
whatVTEC's Avatar
Default Re: How can I fix a grind in Third gear? (Waachback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Waachback &raquo;</TD></TR><TR><TD CLASS="quote">#12345349 and #12377916</TD></TR></TABLE>
What's the difference between the 2 numbers?
Different sizes?
Old Oct 8, 2003 | 02:49 PM
hybridEj6's Avatar
Will this prevent future grinding?
Old Oct 8, 2003 | 03:09 PM
mdelena's Avatar
The stuff works... but will only help for so long.
Grinding means the syncros (blocking rings) are wearing out.. the syncromesh will help but not fix the problem
Old Oct 8, 2003 | 03:36 PM
whatVTEC's Avatar
Default Re: (mdelena)
Is it ok to use with a quiafe? My tranny isn't grinding yet but I'm sure it wouldn't hurt to start using this?
Old Oct 8, 2003 | 03:43 PM
Kwuaymaikrup's Avatar
Sounds easy but.....where do you get third gear synchros for a JDM trans?
Old Oct 8, 2003 | 06:55 PM
maxrpm's Avatar
rebuild your tranny or use lucas tranny oil. I used it in my tranny and the gears go in smother now.
F22dreams
Dec 13, 2007 12:46 PM
wallawee
Jul 29, 2006 05:43 PM
superhatchbackbros
10
May 30, 2006 10:19 PM
shawn_crx
Jun 29, 2005 11:18 AM
LSEGHATCH
Feb 15, 2005 05:45 AM
