tranny questions
Old Jul 10, 2004 | 09:48 AM
j_max420's Avatar
Default tranny questions
i have a 1991 hatch with a b16a vtec, 5th gear at 55 mph runs 3500, i need another tranny that will help with the higher rpm at higher speeds. the car feels as if it needs another gear, so what i want is something that wont run such a high rpm at higher speeds, any suggestions
Old Jul 10, 2004 | 10:14 AM
Katman's Avatar
Default Re: tranny questions (j_max420)
you can try swapping in an 90-91 LS 5th gear into your tranny. Actually what B16 tranny do you have exactly? S1, J1, Y1, YS1?
Old Jul 10, 2004 | 12:15 PM
j_max420's Avatar
Default Re: tranny questions (Katman)
i believe its a y1, see i bought the swap from a place and it came with the engine
Old Jul 10, 2004 | 03:46 PM
slo2kgsr's Avatar
You could ask someone with a ls or gsr to trade trannys with you. I would only step down to a GSR however.
Old Jul 10, 2004 | 06:59 PM
j_max420's Avatar
Default Re: tranny questions (tegraLS97)
what transmissions will work, so i have a selection
Old Jul 11, 2004 | 12:50 AM
honda_power69's Avatar
If you're happy with the way the other gears are, then why swap the entire tranny?
Seems the logical thing to do would be swap out the 5th/reverse gear set like you were saying. Kinda pricey from the dealer, but definately cheaper than a new tranny.
Another route would be to just swap an ls/gs/rs integra final drive gear in. The end result would definately give you a lower rev/speed ratio in 5th without adversely affecting the other gears. Although you would notice a difference in all gears with this setup.... so I guess it kinda just depends on what you want.
martymart92
Transmission & Drivetrain
21
Feb 10, 2010 12:42 PM
Crisgo
Dec 5, 2002 02:33 PM
