Tranny problems..need help!!
Old Mar 30, 2005 | 07:38 AM
fkncivic's Avatar
Default Tranny problems..need help!!
clutch pedal doesnt have good pressure and i just replaced the slave and master cylinders, no holes in any lines and no fluid loss, when i do get it into gear the clutch doesnt disengage when i press the pedal in but most of the time i cant get it into gear.... any ideas?
Old Mar 30, 2005 | 08:03 AM
Dragline's Avatar
Default Re: Tranny problems..need help!! (fkncivic)
Sounds like you need a new clutch.
Old Mar 30, 2005 | 08:06 AM
fkncivic's Avatar
Default Re: Tranny problems..need help!! (dragline)
clutch never slipped and i had act check the pressure plate, it is an act xtreme pp with street disc....act said the pp was fine
Old Mar 30, 2005 | 08:44 AM
fkncivic's Avatar
anybody got any ideas cause im stumped on this one..
Old Mar 30, 2005 | 08:58 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Bleed it more? How did you bleed the slave? You have to pump it until you get pressure, put it to the floor, then close the bleeder valve. Repeat.
Old Mar 30, 2005 | 09:02 AM
fkncivic's Avatar
there is no air coming out of the system.. all fluid
Old Mar 30, 2005 | 09:22 AM
fkncivic's Avatar
i really dont see this as a hydrolic problem, but to give you a little history, last summer i was doing some spirited driving before i went home well i parked the car and when i got up the next day i went out and could not press the clutch in, it was stuck in the upward position well i went under the hood to look and i noticed that the lever arm was stuck up and i tapped it with a hammer and it went back down well it seemed fine after that only fealt like i had less clutch pressure and the engagement point was really low to the floor. next it started to do this **** where i had to pump the clutch to get it into gear so i replaced the slave and master cylinders and it is still doing it but has gotten to the point where i cant even get it into gear. any ideas?
Old Mar 30, 2005 | 11:17 AM
fkncivic's Avatar
bump
Old Apr 1, 2005 | 10:27 PM
fkncivic's Avatar
bump, i would really like some advise on this so that i know where to start
Old Apr 2, 2005 | 06:32 AM
Dragline's Avatar
Sounds like your throw out bearing is hanging up you probably need to grease the column it slides on.
Old Apr 4, 2005 | 07:28 AM
fkncivic's Avatar
bump.. any more thoughts on this?
ohsojdmdc
Jul 30, 2014 08:37 AM
kevinm1981
May 8, 2010 08:43 PM
melikeyjdm
Feb 13, 2008 04:58 PM
DrVtec99
Oct 7, 2004 07:09 PM
skierGT
Jul 23, 2003 12:29 PM
