Tranny Problem.. Please help.. Already Searched.
Old Dec 9, 2006 | 11:10 AM
ek_b16's Avatar
Default Tranny Problem.. Please help.. Already Searched.
My buddys gsr is having tranny issues.. The tranny doesnt grind but heres the problem.. U cant put the car in gear when its on but if u turn it off then u can find only 3rd 4th and reverse. Either way its pointless because Theres no neutral. Even when its in neutral the car still drives as if its in 4th gear. Mainly the only way to get the car to move is to leave it in neutral which is 4th gear and ride the clutch hella by giving it gas.. thats the only gear that works.. Can anyone give me some pointers on what it could be?? I'm thinking either the shifter fork or clutch.. any advice is needed.. thanks in advance..
Old Dec 9, 2006 | 12:00 PM
RTW DC2R's Avatar
if you can select 3rd 4th and R then I dont think its the clutch. did you check the fluid? was the tranny working previously and has anything changed since it was working properly?
Old Dec 10, 2006 | 10:19 PM
ek_b16's Avatar
Default Re: (RTW DC2R)
u can only get into those gears sometime when the car is turned off.. The tranny was working fine then it just gave out while he was driving home. the fluids are full.. I wont know anything till i start to take it apart..
gq420j
Dec 24, 2007 08:58 PM
polishedturd
Nov 29, 2007 05:59 AM
DA9teg93
Jun 12, 2005 04:09 AM
BlueIntegraBoy
Jul 25, 2004 11:57 AM
stilzx61
Feb 14, 2004 01:28 AM
