tranny problem
Old Jul 24, 2004 | 02:08 AM
emendgroove1's Avatar
Default tranny problem
ok i got a 99-00 si tranny and i was driving on the freeway when all of a sudden my **** just popped out of gear so i tryed to put it back in but no use in any gear. what do you think the problem is. i had my friend take off the tranny of my car and hes got the clutch and everything out but he didnt open up the actual tranny to see if any syncros or bearings are messed up. but before i do that what do you think is wrong? i tried to start the car and it will go in gear but just whistles. sort of a whistle sound. but any info would be gladly appreciated.
Old Jul 25, 2004 | 02:10 AM
ttt
anybody???
before i buy some new syncros off ebay
cuz most likely thats what it is
Old Jul 25, 2004 | 05:03 AM
Rod.'s Avatar
Default Re: (emendgroove1)
i am voting on synchros also if it popped out of gear
Old Jul 25, 2004 | 11:25 PM
PupaScoopa's Avatar
Default Re: (redturbocivic)
If it pops out of gear, that's usually bent shift forks. Did it go into gear after you stopped? Did you try to bleed the clutch lines first? Was the master/slave cylinder in good shape?
Since the transmission is out, you might as well crack it open to check things out. It's tough to tell weather the synchro hub is worn or not. You can definitely inspect the shift forks and shift piece; make sure everything is within spec.
Old Jul 26, 2004 | 12:47 AM
hmmmm...since i put some new rear trailing arms my brakes stopped working. i would have to put brake fluid in that **** everyday. dunno tho...hopefully its just the syncros. after i pulled over when it broke down it would go in gear but just whistled. and wouldnt go anywhere. any more info would be appreciated.
Old Jul 27, 2004 | 05:34 PM
Forest1's Avatar
if it pops out of gear while driving, its time for a tranny replacement...its internally shot...
Shawn
Old Jul 27, 2004 | 05:43 PM
mmuller's Avatar
Mad Scientist
Default Re: (Forest1)
if it would pop out of gear in one gear, then i would say its your synchro; but since you say its in all gears it's most likely shift forks
Old Jul 27, 2004 | 06:11 PM
the shift forks???...more specific...not new to this **** but tranny **** yes..
jordan_rael_420
Oct 18, 2010 04:57 PM
jdmej2lolo
Oct 17, 2008 09:13 AM
BlueIntegraBoy
Jul 25, 2004 11:57 AM
93 EH3
Aug 13, 2002 02:55 AM
