TPS voltage reversed (inverted)
Old Jan 3, 2010 | 06:06 PM
1Bluegsr's Avatar
Default TPS voltage reversed (inverted)
I have a pr3 OBD0 ecu running a B16A engine and my TPS voltage at idle is 4.6 and at WOT it is 0.7 My ecu doesnt throw any code and the engine seems to run alright most of the time but the rpm that the vtec kicks in at is anywhere from 4k to 6k depending on the throttle position. Has anyone had this problem?
I know the the TPS is normally suppose to be .5 at idle and 4.5 at WOT. Please help
Old Jan 3, 2010 | 11:44 PM
delsolproblems's Avatar
Default Re: TPS voltage reversed (inverted)
The TPS must be tested with the engine not running and the key in the ON position.
Old Jan 4, 2010 | 11:12 AM
1Bluegsr's Avatar
I know, that is how I was able to get the voltage readings I listed above.
Old Jan 4, 2010 | 11:48 AM
If you tested it properly, make sure the TPS isn't mounted upside down.
Old Jan 7, 2010 | 06:11 AM
1Bluegsr's Avatar
Has anyone else had these issues?
Old Jan 8, 2010 | 10:25 PM
1Bluegsr's Avatar
please help
Old Jan 9, 2010 | 07:05 AM
Make sure that the wires run from the correct terminals on the TPS to the correct ones on the ECU and that none are switched. If the TPS is hooked up properly, you'll need to replace it.
Old Jan 15, 2010 | 10:12 PM
1Bluegsr's Avatar
I checked that. Has anyone had this problem before?
Old Jan 15, 2010 | 11:15 PM
Rigginit's Avatar
I think it's more of a "Your leads are reversed" type of problem
-positive probe to the center(signal) wire and the negative probe to the ground wire will yield the proper results..
whereas ...
-Positive probe in the center and negative probe on the positive side will read the results you have with 5v at idle.
From front of Vehicle (EG Civic shown, yours similar)
Old Jan 16, 2010 | 09:05 AM
1Bluegsr's Avatar
I will try that as soon as soon as i get it back together. But I dont think that is true because if I take my multi meter and and put the positive lead on the negative post of the battery and the negative lead on the positive post it gives me the same voltage but a different sign (-12 votls). So with that said I am guessing doing what you said will give me (-4.5 to -.5) instead of what I am getting now (4.5 to .5)
Old Jan 16, 2010 | 12:12 PM
Rigginit's Avatar
That would be true if you were to simply switch the probes between the Positive wire and the middle sensor wire. But you are switching the negative probe to the actual negative wire. I did this on my car on purpose to be sure before i posted my original response You'll be good to go.
lshatch1.8
Jan 8, 2008 12:33 AM
wade
May 31, 2004 12:32 AM
Darkteg
Aug 17, 2003 12:47 PM
AcCoRdStReEtRaCeR
Jan 30, 2003 08:08 PM
