TPS voltage problem
I was replacing my tps on my p73 intake manifold and I went to go check voltage between the yellow wire and the ground and I was getting a reading of .27 which is weird because it is supposed to be 5v. So I switched out the ecu just in case and im still getting the same reading. For a procedure so "simple" as calibrating, it's becoming increasingly difficult if it's not reading right. If anyone has any input on my situation please contribute.
besides that could there be any other causes?
How are you checking the sensor? Have you checked for 5v from the neg battery to the yellow cable?
If your not getting 5v there then trace back to the ecu.
If you are getting 5v then probe the grn/blk wire and apply your probe to the negative side of the battery and check for continuity. Should be very low less than 1 ohms.
I probed the 5v constant at the ecu and im getting .27v at this point I have no idea what to do
UPDATE: for the hell of it I probed the 5v constant for the map sensor and im getting the exact same reading as the TPS
well i tested both ecus and they were previously working perfectly on my other set ups. I guess i'll pick up another ecu just to make sure. Until then is there ANYTHING ELSE i should check?
I check the voltage in both igp1 and 2 and they read the voltage of the battery, which i had tested today and is in perfect working condition. Previous to me wanting to replace the tps the car turned on and worked, the idle was a bit erractic and it died out sometimes at a stop (obviously because of the TPS)
If two ecus doing the same thing, it's likely not the ECU, esp if you already tested it on another car. (before and after I hope?)
Take off TPS connector / remove tb, check for resistance at the terminals (since you have the wiring diagram, I'm sure you know what to do. This is the easiest, thus do this first. you should have varying resistance when rotating the tps. If you have no continuity/very high resistance at stock/fully closed position, change TPS, it's shot. Usual reading is 800-900ohms (sometimes a little more, depending on TPS age) at fully closed position. You can adjust the TPS to these numbers at least if you don't have the 5V to reference. It should get very close with the above readings.
If you're not getting 0-4.5V on the tps signal wire and ground,
There's 3 wires on the thing: the sensor power wire, the signal wire, and the ground wire. they're all traceable back to the ECU, check for continuity for each, this will determine if you have an open circuit on any of three wires. If they check out okay, then it means you have a short. Locate by checking for continuity between the three wires, and also with ground to confirm.
All this can be done without switching on the car.
You wouldn't want to do that and fry another ECU if you have a short.
marcj
Jun 17, 2009 11:18 AM
AndyD
Jun 3, 2004 04:38 AM
