tps question
Old Mar 23, 2009 | 11:02 AM
turboef90's Avatar
Default tps question
i have a my voltmeter set a 20v when i hook + to the middle wire i get 5. no matter how i move my tps. if it is bad wouldnt it not even read?? wouldnt it make my car run rich as hell?? its boosted as well but when i took my spark plugs out they looked like its running lean. my aem wideband says its running rich in boosted.
Old Mar 23, 2009 | 11:46 AM
turboedsupe's Avatar
Default Re: tps question
You are supposed to hook it up to the ecu pins. If its a obd-1 ecu its d22 (ground) and d11 (power) with the key in the on position
Old Mar 23, 2009 | 12:18 PM
turboef90's Avatar
that will give me the volts out of the ecu. i need to know if my tps is screw or not. i found this.http://www.clubintegra.com/board/showthread.php?t=21792 tho desont really help but told me. how to do it
HondaCL2.0
Engine Management and Tuning
May 13, 2017 07:37 AM
Corksil
23
Jul 14, 2011 05:59 PM
jord18
Aug 11, 2009 01:32 PM
crapanese
Aug 7, 2006 11:40 PM
Acrappyhatch
May 24, 2006 06:50 AM
