tps not matching up to volt specs?
Old Apr 27, 2011 | 09:32 PM
blackedEk's Avatar
Default tps not calibrating to volt specs?
like title says, done this before many times. I even swapped 2 good known working ones, still not matching up.
for instance, its supposed to be .5 at closed throttle and 4.5 at wide open.
here is the problem, when i set it on .5 spec on closed throttle the wide open would be off, at like 4.35 and will not match up.
Also, tried the opposite, got it perfect on 4.5 spec but the closed throttle spec would be off as well..and yes i know there is a slot for the arm to go into
I have all the symptoms of a bad/unadjusted tps, but in my case its only out of spec, the sensor itself is good.
throttle plate is closed 100%
no tension on the cable
idle screw is fine
no CEL
weird, never had this happen before, its usually fairly simple to get the specs matched up.. any idea ?
Old Apr 28, 2011 | 05:00 AM
Jenkinsal2's Avatar
Default Re: tps not calibrating to volt specs?
idle screw is fine
no CEL
The way that the sensor works you may not always have both sitting perfectly on the correct values. Yours is very close. I would check to make sure you arent dropping out mid throttle. It should be smooth from .5 to 4.5.
Old Apr 28, 2011 | 03:10 PM
blackedEk's Avatar
Default Re: tps not matching up to volt specs?
no dropping, its smooth
messed with it today, got it at .67 closed and 4.50 open
cant seem to get em matched, never thought this would be this complicated
portenio78
Engine Management and Tuning
Sep 2, 2012 11:52 AM
toolbox21
Dec 8, 2009 04:59 PM
LSVTEC 91 Civic
15
Oct 28, 2005 06:16 PM
miahmouse
Oct 7, 2002 09:24 AM
