tps??
Old Feb 15, 2002 | 05:10 PM
iwhichisme's Avatar
Default tps??
Hey im getting code 7 which i beleive to be tps, how in world do you set it so that it reads right, my car is idling funny, and boggs like hell, slow as ****.
by the way i have a b16a swap in a ef.
thanx
Old Feb 15, 2002 | 07:11 PM
tinkerbell's Avatar
Default Re: tps?? (iwhichisme)
it may be faulty but you can check it...
you can set the TPS so it shows 0.5v at closed throttle,
do this by measure tthe voltage on the signal wire (not the 5v one)
by undoing the screws that hold it in and moving it the tps signal should change...
do you have a shop manual?
hth,
t..
Old Feb 15, 2002 | 07:37 PM
iwhichisme's Avatar
Default Re: tps?? (tinkerbell)
no id ont really have a manual, i guess ill just have to play with it, until i get it right. WHat happen was i got the tps off my single cam, because it the dohc tps came broke off as they often do. I screwed on the tps, but i guess its not set where it should be, ill try the method you supplied, thanx for your info.
peace,
RinzEG6
Nov 22, 2015 11:25 AM
SoHc94
Mar 6, 2011 08:34 PM
gibsanez
Feb 17, 2008 11:39 AM
hOndafienD 04
Aug 26, 2004 12:51 AM
CRX A4
Jun 14, 2003 09:43 AM
