Town Fair did a bad alignment....??
I just got a 4 wheel alignment done at Town Fair Tire and the car still pulls to the right. The front two tires are practically new, and the rear maybe 80%, but all have even tread.
Anyone have a problem with a shop doing a bad alignment? Should i take it back... I mean, a lot of people i know have cars that pull to the right, but ****, after an alignment? The only other thing it could be is the tire wear, but like i said the good years in the front are pretty much new. Visually, I know its hard to tell, caster on pass wheel seems positve, and toe on both seems off.
when we do alignments, we usually check out the front end of the car before we touch anything...do you know if they did this before they aligned your car? Checking for bad ball joints, tie rod ends, etc, etc. You could check out the front end of ur car by urself too...also is the car dropped at all? And if so, do you have the camber kit? Some shops won't adjust the camber of the wheel (the wearing along the inside of ur tires) unless you have the right camber kit. Most just adjust the toe and call it a day.
