Torquing with trans in gear
Old Nov 13, 2016 | 06:07 PM
lolv8s's Avatar
10 Year Member
Default Torquing with trans in gear
is it safe to torque my axle nuts with the trans in gear? (134ft pounds) and my ati fluidamper has to be torqued too. Is it safe to do so with the trans in gear?
Old Nov 14, 2016 | 08:01 AM
holmesnmanny's Avatar
Default Re: Torquing with trans in gear
just stick an allen wrench into the caliper in between the rotor fins with the brakes installed and the car in neutral, it will bottom out against the caliper which will lock it so you can torque the axle nut, you can even start the car and have someone push the brakes to lock it
Old Nov 14, 2016 | 08:12 AM
lolv8s's Avatar
10 Year Member
thats the thing... I haven't started it yet. still running coolant hoses. and questioning if i need to pull my swap because i used arp main studs and I dont remember if i had it line honed, but an allen wrench in the caliper? what about the harmonic balancer? (ati fluidamper)
Old Nov 14, 2016 | 10:03 PM
then just use the allen wrench method
Tyler Atwood
Jul 2, 2019 04:40 AM
radiotech
Transmission & Drivetrain
Apr 29, 2018 08:59 AM
J4k3
20
Mar 12, 2012 05:58 AM
dazelman
May 27, 2010 11:34 AM
