torque spec ? for valve cover and studs.
I replaced my valve cover gasket the other day and over torqued 2 of the studs. They happened to be to 2 the ones that also hold down the cam caps( the 4 studs in the middle of the valve cover between spark plug wires). I got two new studs but I need to know the torque specs and the studs need tightened down to on the cam caps, and also so I don't bust anymore studs, what are the torque specs for the nuts that tighten down the valve cover?
thanks
thanks
please someone help. Ive been told 12lbs, 16lbs,20lbs. I just don't wan to screw anything up in the motor. Its the bolts/studs that go on the cam covers underneath the valve cover.
just tighten them hand tight, and turn the wrench 1/8th of a turn and you should be good to go, aluminum ***** up easy so dont tighten too much, and they dont need to be too tight
acmoc
Jul 3, 2008 05:39 PM
BrianCivicDX
Oct 3, 2006 02:57 PM
