torque needed on arp head studs on gsr motor
Old Aug 11, 2005 | 02:30 PM
92gsrteg's Avatar
Default torque needed on arp head studs on gsr motor
as stated in the title. what torque do i tighten the arp head studs to on a 95 gsr motor?. thanks
Old Aug 12, 2005 | 02:41 AM
eg6T's Avatar
Default Re: torque needed on arp head studs on gsr motor (92gsrteg)
im not positive on the gsr motor but i think it would be the same as i installed them on ls/vtec...
direction say using ARP moly lube- hand tighten them into the block,put head on(obviously) and tighten nuts to 65 ft/lbs
i first tighten them all to 40 ft/lbs,then came back around and made them all 65 ft/lbs
if you are going to use oil and not arp moly lube i think its 70 ft/lbs,dont quote me on that..
junior40er
Jun 20, 2006 09:35 AM
slayersluck
Mar 25, 2006 11:50 PM
eRACING
Aug 15, 2004 08:19 PM
