is this Top Dead Center?
Old Jan 10, 2006 | 12:34 PM
alleyezonme's Avatar
Default is this Top Dead Center?
it looks like it to me, but the car won't start and i have fuel and spark. When the cams are perfect at TDC this is what the flywheel looks like...
I know it looks like it is, but when I took this picture I was standing like right inline with the header, so it is kinda manipulated. I guess what I am really asking, is where should I be standing to look at it, because if I kneel down in front of it the mark will at a different spot then if I stand up next to it. get it??
thanks travis
Old Jan 10, 2006 | 12:51 PM
tgreaves's Avatar
Default Re: is this Top Dead Center? (alleyezonme)
Look at the timing mark on the crank pulley.. If you put the flywheel on a different way, the timing marks will not line up correctly.. The crank pulley is keyed so there is only one way to put it on..
Old Jan 10, 2006 | 01:05 PM
Default Re: is this Top Dead Center? (tgreaves)
I thought the flywheel was too though... I just don't wanna rip the alternator off and the plastic!! It is a tight fit...
Old Jan 10, 2006 | 01:13 PM
tgreaves's Avatar
Just look down the drivers side of the engine and youll see it..
Old Jan 11, 2006 | 02:59 AM
its an h22 so it is burried in there!!! i guess there is no other way though, thanks for the help man
Old Jan 11, 2006 | 10:26 AM
MrParks's Avatar
no that is not tdc. !!!!! if this is an h-f series block the tdc marks are on the other side of that mark there is an x an couple of other lines scribed in there chk it if you want to do it the stupid way take you #1or4 plug out and put a 3/8'' ext a long one and see when it comes up exactly to the top ok see if this would help but you are not looking at tdc there
Old Jan 11, 2006 | 12:02 PM
Default Re: is this Top Dead Center? (GHOSTWORKS)
are you saying all of those marks should be on the flywheel??? because it is an aftermarket flywheel and that is the only mark on it!
Old Jan 11, 2006 | 05:57 PM
skeeterd16y7's Avatar
TAKE THE #1 PLUG OUT AND SEE IF IT AT THE TOP.IF ITS NOT SLOWLY MOVE IT UNTIL IT DOES THEN LOOK AT YOUR MARK.YOU CAN USE A LONG SCREW DRIVER OR SOCKET EXTENSION TO TELL WHERE IT IS.ITS KINDA TOUGH UNLESS YOU HAVE ALL THE PLUGS LOOSE BCAUSE OF COMPRESSION.
Old Jan 11, 2006 | 06:07 PM
Tad's Avatar
Tad
taking the plug out and feeling if its at the top will NOT tell you if its at tdc
when a piston hits the top, it "floats" there for a moment before going back down.
so you'd have to turn the engine till the piston had been floating there exactly half of its time..
how the **** r u going to get that accurate!??!
just look at the crank pulley markings like the helms tells u to
Old Jan 11, 2006 | 06:15 PM
Default Re: (Tad)
it floats maybe 1 degree.thats where common sense comes into play.
Old Jan 12, 2006 | 03:00 AM
Default Re: (skeeterd16y7)
I thought was the stupid way
I will probably end up just doing it this way just to get me into the ballpark. thanks
dfoxengr
Welding / Fabrication
30
May 18, 2005 07:32 PM
h22a193
Dec 8, 2004 12:34 PM
Maddox
Feb 29, 2004 07:24 PM
preluda92
Oct 24, 2003 09:41 AM
boomslang
Nov 30, 2001 06:48 AM
