tool for locking cam gears...
there was a tool that goes in between for cam gears so they wont move...ive seen it in a picture of endyn building an engine but cant remeneber the name or where to get it...aftermarket cams dont have the holes to lock them...
http://www.sears.com/shc/s/p_10153_1...u=SPM222401870
But this looks way more awesome to me:
http://www.rs25.com/forums/f134/t149...3-98-dohc.html
By the way i found that all with a 5 second google sarch...
From: That's the wrong tone... I'm Skunk2 certified.
hm, good to know that aftemarket cams dont have those holes. hey skunk2, if your reading this, put some holes in your pro series cams before i buy a set plz kthx.
otherwise, i'm in the market for one of these things, too.
First of all, why would you want to stick something in the cam gears to lock them in place? Are you trying to tighten the cam gear bolt? All you have to do is use an adjustable wrench and old down on the camshaft. No need to buy specialty tools for a simple job, folks.
Lock at the points encircled in RED:
he wants a tool because vtec motors dont have the flat spots on the cams. they have holes in them you can lock with allen keys but they dont do that great of a job
in for results
in for results
IF he is referring to a DOHC VTEC motor, then it is possible to use a 19mm pry bar and lock down the crank pulley...with the timing belt still attached of course. The torque spec for the cam gear bolt is less than 30lbs ft. if I remember correctly.
http://www.lislecorp.com/search/ this one works pretty good you can get it from carquest $39.99
evolution industries has one for 25 bucks....so you can lock cam gears while adjusting them..one piece design specialy for b series...aftermarket cams live sk2 and bc..dont have the holes so you can use the 2 drill bits...so you have to find another way to torque cam gears and adjust cam gear angles...
dwnthehatch
Apr 18, 2005 07:01 PM
