Tired of the msd switch how do i do it right???
Old Jul 13, 2004 | 03:11 PM
KiNG $h!t's Avatar
Default Tired of the msd switch how do i do it right???
Ok i am running a msd vtec engagement switch right now on my lsvtec with a chipped ls ecu.... but now it is time to move on and do it the right way. What all do i need to do to run a p28 or a b16 or gsr ecu?? By the way it already has a gsr wire harness and and the motor is obd1... thanx i appreciate all the help you have to offer me
Old Jul 13, 2004 | 03:23 PM
Kendall's Avatar
You'll need to run the wire from the VTEC solenoid to the ECU. You'll also need to run a wire from the Pressure switch to the ECU, and a chassis ground from the Pressure switch to the ECU. Being that you already have a GSR harness, it may make sense to run the wires from where the engine harness plugs into the chassis harness. however I think it's easier to just run them from the components to the ECU.
luvmihatch
Oct 5, 2008 10:34 AM
30MadMax30
Honda Civic (2006 - 2015)
Jun 6, 2008 12:58 PM
KiNG $h!t
Jul 20, 2004 04:36 AM
InfamousRS
May 14, 2002 07:23 PM
