Timing belt tensioner
ok guys i did a search and read through all 3 pages worth.
but what i really wanna know is how does the tensioner actually work???
i see theres a spring that pulls it ? but what happens when u loosen the 14mm? tighten the 14mm??
thanks
thanks
There is a spring for the tensioner, you're right. When you loosen the 14mm bolt, it allows you to relieve the tension off of the belt by sliding it down in the guideway it rests in. Before you tighten it, you have the turn the crank pulley 6 times counterclockwise, and then tighten the 14mm bolt.
edit: rereading this I realize I'm not 100% sure how the tensioner works exactly...but that's what I understand.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">Never heard of turning it 6 times, I always just move it 3 teeth counter clockwise..</TD></TR></TABLE>
3 teeth?? Do you mean cam gears??? Crank pulley doesn't have teeth. I am kinda confused here.
Just move the cam gears 3 teeth by turning the crank. This creates tension on the timing belt so can then tighten the 14mm bolt.
ok so from what i understand, when the 14mm bolt is loosened u crank the cams 3 degrees counter clockwise to tighten up the belt , then u tighten the 14mm bolt back up??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO »</TD></TR><TR><TD CLASS="quote">
3 teeth?? Do you mean cam gears??? Crank pulley doesn't have teeth. I am kinda confused here.</TD></TR></TABLE>
Yes, 3 teeth on the cam gear.. The crank does have teeth its just hidden behind the crank pulley..
