Timing belt tension noise
Old Aug 22, 2004 | 02:16 PM
User 5426's Avatar
Default Timing belt tension noise
Reciently my h22a's auto tensioner went out. Which caused it to make a loud noise when I let off the gas anything higher than 3.5k and it will stop at around 2k. I got the auto tensioner replaced with a manual tensioner and the noise was completely gone till I drove it on the freeway. The noise is much more quieter but it is still there.
I adjusted the tension on the manual tensioner by:
1) removing the valve cover
2) setting the engine at TDC
3) loosening and tightining the adjuster nut
4) turning the crankshaft 3 teeth counter-clockwise
5) loosening and tightining the adjuster nut.
After doing this I still notice the sound.
I've already adjusted it 4 times and during some of those times, it will go away for a few minutes and come right back. Is it that the manual tensioner doesent hold it's tension?
PLEASE, help a brother out.
99cbm
Dec 23, 2013 05:59 AM
micah_m
Jul 26, 2013 09:09 AM
MeathooK
Sep 12, 2008 08:54 PM
User 5426
Aug 22, 2004 11:10 PM
User 5426
Aug 21, 2004 02:08 AM
