Timing Belt Issues
Ok, here is my problem! I changed my water pump that was on my B20Z2 with a 99 GSR pump. I also bought a GSR timing belt. I can't seam to get the timing belt to tighten up. I have an all motor non-vetc setup. Should I have used the same B20 belt? This is what I think the problem is however, I would like to see what someone else has to say.
The gsr water pump isn't "better" than a b20 or ls pump.It has more teeth so that the pump turns slower at high rpm.Not necessarily the best thing on a lower reving non-vtec engine.The gsr belt should be the right one for your setup.
Glenn
Glenn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR »</TD></TR><TR><TD CLASS="quote">The gsr water pump isn't "better" than a b20 or ls pump.It has more teeth so that the pump turns slower at high rpm.Not necessarily the best thing on a lower reving non-vtec engine.The gsr belt should be the right one for your setup.
Glenn</TD></TR></TABLE>Well, that's something I didn't know if that's a true statement. Not that I am saying it's not, it's just that I never heard that before. So, will this pump cause a problem?
UPDATE: After missing around with it a little and using a coat hanger to help pull the tensioner up I got it to tighten really good. Drove it around for about thirty min. and checked it, still the same as when I tighten it. So I guess that spring must be worn.
Kirk@SyndromeAuto
25
Oct 9, 2015 08:03 PM
1SickHb
Oct 4, 2005 09:00 AM
dElSleepiE
Jun 1, 2003 08:56 PM
