timing belt about to fall off??? any reasons why?
Old Dec 16, 2003 | 09:03 PM
SpoolinEK's Avatar
Default timing belt about to fall off??? any reasons why?
like topic says..i have a d15/vtec..the belt is slightly off the pulley..just enough to rub on the covers. any reason why?
Old Dec 16, 2003 | 09:05 PM
mastarolla's Avatar
Default Re: timing belt about to fall off??? any reasons why? (EG Civic)
incorrect tension?
Old Dec 16, 2003 | 09:22 PM
SpoolinEK's Avatar
Default Re: timing belt about to fall off??? any reasons why? (mastarolla)
this is my second block with this same setup..the first one was fine.. i dunno why this one is doing that
Old Dec 16, 2003 | 09:28 PM
blackeg's Avatar
i had my head switched about 30,000 miles after my timing belt was replaced and it was loose as **** and floppin around hittin the cover. push it back onto the camgear and make sure the tensioner is tight. if it happens again id look into the tensioner more
Old Dec 16, 2003 | 09:29 PM
SpoolinEK's Avatar
Default Re: timing belt about to fall off??? any reasons why? (blackeg)
i will try that first thing tmw..
Old Dec 16, 2003 | 10:28 PM
Foozball26's Avatar
slide it back on, put the motor at #1 cyl TDC and make sure the cam timing is correct.
Then loosen the tensioner bolt and rotate the crank 3 teeth past TDC counter clockwise to properly tension the belt, then tighten the tensioner bolt agian.
taken my timing belt off so many times i have memorized the service manual
Old Dec 16, 2003 | 10:52 PM
mastarolla's Avatar
Default Re: timing belt about to fall off??? any reasons why? (Foozball26)
what do u mean 3 teeth..i never did understand that part of the manual...
Old Dec 16, 2003 | 11:24 PM
Foozball26's Avatar
the teeth on the gear on the crank, behind the crank pulley.
the pulley that the belt goes around on the crank.
Old Dec 16, 2003 | 11:25 PM
Foozball26's Avatar
also, if you have the upper cover off you should be able to look down and see the mark on the oil pump housing and just watch as 3 teeth go by and tighten the tensioner bolt back up.
Old Dec 17, 2003 | 06:08 AM
IN VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG Civic &raquo;</TD></TR><TR><TD CLASS="quote">like topic says..i have a d15/vtec..the belt is slightly off the pulley..just enough to rub on the covers. any reason why?</TD></TR></TABLE>
Is that how you found it when you removed the valve cover?
Could be missing a thrust washer down at the timing belt drive sprocket.
Old Dec 17, 2003 | 06:58 AM
NewbyforIntegs's Avatar
YEah this has happend to me to my old car. Timing belt for my ac turned off, didnt have AC for 2 days in the damn summer. it was really loose and didnt spin. All U gotta do is tighten it, and itll be set
Old Dec 17, 2003 | 08:19 AM
BeerMan's Avatar
Default Re: timing belt about to fall off??? any reasons why? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
Could be missing a thrust washer down at the timing belt drive sprocket.</TD></TR></TABLE>
Yeah, sounds like you are missing #12.
http://www.hondaautomotivepart...ISTON
I did this once, but I had the singular pleasure of watching the belt actually start to work its way off before I yelled for my buddy to shut the car off. It was one of those "slow motion" experiences.
Old Dec 17, 2003 | 05:39 PM
SpoolinEK's Avatar
you were right on the dot..yup..forgot to slip it on..everything is A OK now..thanks for the help
giovannie23
Jul 20, 2013 11:52 PM
delsolboi
Mar 13, 2013 11:57 AM
yosuthnmasa
Apr 8, 2008 07:29 AM
mattatchison
Jun 7, 2007 04:58 PM
eddiecut
Jun 16, 2003 12:10 PM
