thrust washers.... how to install?
its a b18c1
i have a manual, but it says to just put them in the number 4 journal. but how exactly do they stay there? what holds them in?
If you are trying to get them to stay put while you set the crank in, try a little assembly lube behind them and that should hold them enough to get the crank installed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicross »</TD></TR><TR><TD CLASS="quote">If you are trying to get them to stay put while you set the crank in, try a little assembly lube behind them and that should hold them enough to get the crank installed.</TD></TR></TABLE>
thats what I tried and it kept binding up. If that doesn't work.. what I did was put the crank in, slid one in, then for the second one, i lightly tapped the end of the crank with a rubber mallot, and the other one slid into place. My friend lightly tapped the end and as he was doing that, i was sliding the thrust washer in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiBuddy00 »</TD></TR><TR><TD CLASS="quote">
thats what I tried and it kept binding up. If that doesn't work.. what I did was put the crank in, slid one in, then for the second one, i lightly tapped the end of the crank with a rubber mallot, and the other one slid into place. My friend lightly tapped the end and as he was doing that, i was sliding the thrust washer in.</TD></TR></TABLE>
You can do that too
You can do that too
2002, acura, b18c1, flywheel, honda, install, installation, motorcycle, rsx, sale, thrust, tranmisson, turbo, washer, washers
