thrust washer question
Old Feb 18, 2003 | 03:31 AM
CRXGSR's Avatar
Default thrust washer question
When installing the thrust washer, do the grooves face towards each other or away from each other??
I did a seach and all I came up with is: "the grooves facing toward the crank." (which I don't quite understand )
Here's the original thread: https://honda-tech.com/zerothread?id=260947
Old Feb 18, 2003 | 07:47 AM
IN VTEC's Avatar
Default Re: thrust washer question (CRXGSR)
Grooves face towards the crank. No matter what side you look from.
Old Feb 19, 2003 | 04:48 PM
CRXGSR's Avatar
Default Re: thrust washer question (IN VTEC)
yes, I know the grooves face "towards the crank" already. Maybe I should re-state my question:
There are 2 thrust washers. Each thrust washer has 2 sides (1 grooved, 1 non-grooved). Now when the thrust washers are in place, will the grooves on one thrust washer be facing the the grooves on the other thrust washer, or not?
Old Feb 19, 2003 | 04:53 PM
IN VTEC's Avatar
The grooves face towards the crank journal no matter what side you're looking from.
Old Feb 19, 2003 | 09:28 PM
vhd's Avatar
vhd
when the thrust washer(s) are installed, the smooth side of the thrust washer will go against the block(inward), and the grooved side will go against the thrust surface on the crank(outward). when both are installed, the groove side will face away from each other
Old Feb 20, 2003 | 04:05 AM
CRXGSR's Avatar
Default Re: thrust washer question (vhd)
Thanks vhd, that's whay I was looking for.
juntuned
57
Sep 29, 2006 05:33 PM
CW-ITR
Apr 16, 2004 07:48 PM
