throttle body
Old Apr 15, 2002 | 10:52 AM
gavhowe's Avatar
Default throttle body
What sort of gain do u think a b16 or h22 throttle body will make on a d16z6, do i need to port match it to maximize gains, by the way i have no idea what this port matching is about could some one explian to me about it and were it should be done and may be sizes.
help pls!!!
Old Apr 15, 2002 | 03:16 PM
gavhowe's Avatar
Default Re: throttle body (gavhowe)
some one most under stand what i talking about!
Old Apr 18, 2002 | 08:18 PM
CRXRageD's Avatar
do you know if that throttle body will even fit the bolt pattern on the manifold. I don't know if they are swappable. Also, you might wanna measure it first to make sure that the inner diameters are significantly different.
Old Apr 18, 2002 | 08:21 PM
CRXRageD's Avatar
as far as I know about the b16, it will fit, you won't see anything super different unless you port match the intake manifold to the throttle body. but, there will a small difference.
Old Apr 18, 2002 | 10:18 PM
bananacruzier's Avatar
Default Re: throttle body (CRXRageD)
i had heard that if you bore out your throttle body you will need to recaliberate your throtle sensor or something like that. is this true? if so if i put on a bigger size throttle body wouldn't you need to do that? if this is true who can i take it to to get it recaliberate??
Old Apr 21, 2002 | 11:12 AM
ion_four's Avatar
Default Re: throttle body (bananacruzier)
I had a JG bored TB on my car for a while, but put the stock back on (which I "polished" myself). With the JG I kept getting a CEL until I adjusted the TPS to it's maximum value...you just twist it as far as it will go and it worked fine...I'd think it would also give you better performance.
Old Apr 22, 2002 | 02:41 AM
gavhowe's Avatar
Default Re: throttle body (ion_four)
Sorry mate but what is a CEL and how do u adjust the TPS im getting a B16 throttle body with Map sensor separate on the blulk head the current one on my D16 z6 is on the top of it how do i go about changing things to get it working. how can u improve the b16 throttle body polishing it all what ever as i will be able to play around with it while i still can us the normal one. All responses welcome as i stuck.
Remember Street Racer Is Illegel, But God Is It Fun, Drive Hard FF style
Old Apr 22, 2002 | 05:22 AM
jrsccivic's Avatar
Hey do you wanna sell your tps off the d series throttle body let me know...
Old Apr 22, 2002 | 05:50 AM
gavhowe's Avatar
Default Re: throttle body (jrsccivic)
Not really mate would like to keep it whole as a spare. + i in england which does not help.
Old Apr 22, 2002 | 07:04 AM
Spade's Avatar
Get an integra trottle body. They bolt on.
Take your pic on the size you want.....LS or GSR 60mm Type R 62mm
Old Apr 22, 2002 | 07:18 AM
jrsccivic's Avatar
ok thanx bro
EJtypeR
Jun 17, 2015 08:01 PM
toolbox21
Nov 27, 2008 10:21 AM
tegSB85
Nov 17, 2005 05:50 AM
Fink2iCe
Aug 20, 2004 10:50 AM
Black R
Sep 19, 2001 06:53 PM
