Those running Sk2 Stage 2 pass emissions? Settings?
Old Mar 17, 2003 | 08:01 AM
PSU-TEG's Avatar
Default Those running Sk2 Stage 2 pass emissions? Settings?
I'm running Skunk2 Stage 2's in my 84mm bore B18C w/
- 11.8:1 pistons
- 440cc injectors
- Hondata Stage 2
- Portlfow springs, retainers, Port&Polish
I need to pass emissions.
I was wondering if any of you out here had a similar set-up (or at least with the Stage 2 cams) passed inspection. If so, what was your cam timing set at (what setting would give me the best chance to pass)?
Oh, and I'm outside of Cali, so I don't have to worry about CARB.
Thanks for the help and advice!
[Modified by PSU-TEG, 12:14 PM 3/17/2003]
Old Mar 17, 2003 | 02:55 PM
PSU-TEG's Avatar
Default Re: Those running Sk2 Stage 2 pass emissions? Settings? (PSU-TEG)
Anyone?
Old Mar 17, 2003 | 03:57 PM
riceboyEFsi's Avatar
depending on what kinda car it is IE gsr u may pass , if not good luck im in NY my inspection costed me like $200. and that was from a friend and he didnt even wanna do it i had to bribe him . I guess its all about who u know and how much $$$ u got in your pocket. good luck , i wish i could give u an answer but im just speakin the truth .
[Modified by riceboyEFsi, 9:58 PM 3/17/2003]
Old Mar 17, 2003 | 06:33 PM
91integraLSVTEC's Avatar
Default Re: Those running Sk2 Stage 2 pass emissions? Settings? (riceboyEFsi)
your not going to pass emmisions skunk stage 2 cams are race cams you need to find somebody that will do it for you, of course your gonna have to hit him up wit sum xtra $$$.. i paid dis guy $60 to pass mine..
Old Mar 17, 2003 | 07:00 PM
PSU-TEG's Avatar
Default Re: Those running Sk2 Stage 2 pass emissions? Settings? (91integraLSVTEC)
Yeah, well.... I don't mind paying to be hooked up. But I'm afraid I don't have those connections around me.
Anyone in the Pittsburgh, PA (Westmoreland County actually) area able to hook me up for some $$
I would be much obliged!
Old Mar 17, 2003 | 07:07 PM
MADEINIRAQ's Avatar
maybe tune the hondata for a cleaner burn.. maybe leaner or somethin. i don't really know.
then you can just change out the chip after you pass
Old Mar 17, 2003 | 09:16 PM
b19coupe's Avatar
If your state does not use loaded mode testing, you should be able to squeak by if you lean it out a bit with the Hondata. It will be a close thing though, if you go too lean , you will have a lean misfire. Bump your timing back to 10-12 degrees BTDC. If you have access to a shop that has a four gas analyzer, have them tune it to pass for you. Good luck.
[Modified by b19coupe, 10:16 PM 3/17/2003]
TeamObC408
Feb 7, 2005 05:27 AM
TypeRPaul
Oct 2, 2004 01:38 AM
jeffk182
May 12, 2004 01:43 PM
mildly.interesting
Jan 22, 2003 05:33 PM
96tegsr
Oct 22, 2002 03:11 PM
